02 sensors before and after catalyst?
hey guys,
I am planning on redoing on exhaust within the next few weeks and seeing my check engine light is coming on im going to replace the 02 sensors as well. I know there are two O2 sensors right before the precats are these the before catalyst 02 sensors? If so then where are the after catalyst 02 sensors? And should i replace both? thanks! |
On the 1992-1995 SVX (OBDI) there are only 2 O2 sensors, located before the two small front converters.
On the 1996-97 (OBDII) SVX's, there is a third O2 sensor, located on the rear of the main (rear) catalytic converter. I think its main purpose is just to monitor the operation of the 2 front O2 sensors. .
The rear sensor monitors the convertor's ability to store O2, or, in other words, it's efficiency.
Thanks Beav
Your imput is always appreciated,
WGJ |
thanks now i just have to order the parts!
