Old 05-12-2006, 07:51 AM
Cross member as a jack point?
I've been using the cross member to jack up the front of the car and putting the jack stands on the two parts of the frame on either side of the cross member, is that a bad thing? I've noticed some indentations on the cross member, i just hope i haven't messed anything up. I have the manuals which show the jack points but i am just to leary of the jacks going straight through the floor panels!!
Old 05-12-2006, 08:37 AM
It's Just Eric's Avatar
Missing in action
the engine crossmember? Its fine to jack from there
the little tension bar slightly behind that which could be considered a crossmember...your asking to be crushed
the transmission crossmember....too far under the car to jack from, and even if you could reach it...dont bother. its not that sturdy
the factory jack points are right along the car's frame rails (unibody style) theres no way they will get messed up.
When jacking the car up (And ive done this plenty enough) I jack by the jack points, engine crosmember, and the rear diff, and in the case of my fwd svx, the rear tow hook
R.I.P Cool Signature.
Old 05-12-2006, 09:52 AM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I jack mine at the front tow hooks...they were already folded and bent over when I bought the car, so it works for me and I don't have to run the jack too far under the car.
1995 Subaru Svx L / AWD
Old 05-27-2006, 10:03 AM
dromano's Avatar
dromano dromano is offline
front wheels
Looked in your locker. The pics of the SVX on the trailer, front wheels are on the wrong side.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 05-27-2006, 10:32 AM
mbtoloczko's Avatar
sans SVX
I use the front suspension crossmember all the time. I always put a block of 1x4 pine between the jack and the crossmember. Watch out for the PS lines behind the crossmember. If you hit those, you could tear out a PS line.
Mychailo
Visit my locker
Old 05-30-2006, 04:25 AM
msvx95's Avatar
It's just a phase
Yes, I know.....Fixed when I got it home.
Old 05-31-2006, 06:29 AM
floatingkiwi's Avatar
floatingkiwi floatingkiwi is offline
A flight-less flyer
Send a message via Yahoo to floatingkiwi
I'd have to disagree with the use of the rear diff though - it rips the two rubber mounts that you can see from the rear of the car. At the very least it compresses them as they are now taking the weight of the rear of the car.
'92 JDM (E) Burgandy/Black 100Km
Just Crusin'
Old 05-31-2006, 10:40 AM
Not mine. I'm still waiting for more to be made but the polyurethane mounts I have will never rip
(see group buy forum)
