Old 04-21-2006, 01:57 AM
Green1995SVX
Originally Posted by orangeSVX
i will try that tomorrow thanks. im not clear where to put that tool..somewhere hidden behind the A pillar garnish?
When you pull off the interior panel, you'll see the seat belt unit/motor. right in the middle is a nut thingy (technical term) where you can stick the console tool to crank it. You cant miss it.
Mike
Old 04-21-2006, 04:14 PM
orangeSVX
thanks, i got that far..but when i open the door it returns to the open position and wont go back when i shut the door and turn it on! again!
i'll keep messing with it.
Old 05-11-2006, 06:02 AM
DWAYN DWAYN is offline
When My Drivers Side Seat Belt Was Stuck In The Open Position
The Shop Told Me I Needed A New Track
So I Bought One And Installed It.
It Didn't Help.
I Replaced The Seatbelt Control Unit That Is Located In The Top Of The Trunk Under The Rear Window.
It Has Worked Fine Ever Since.
Still It May Not Be What Is Wrong With Your Car.
DWAYN
