Compatibility between OBD-I and OBD-II SVXs, 5spd 96-97 SVX??
If I were to buy a 97 SVX and use my 92 as a parts car would it work? I know the OBD-II is completely different in the sense of the ecu and sensors it monitors. So how much of my 92 would I be able to use (engine/mechanical wise)?
Also - has anyone done a 5spd swap on a 96-97 SVX? The TCU is built into the ECU on them correct? Sounds like a headache.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
the engine is a direct swap. Only things are the egt(exhaust gas temp sensor) and the SAIC(Secondary Air Idle Controller) sensors. THe 97 will have an EGT and the 97 motor will not have a SAIC. The ECU is different but they still have seperated TCU's which can simply be removed. I beieve there are a couple mt 96&97's around
Tom |
Who has a 96 or 97 with a 5/6MT?
It would be a pita, but you DO have the wiring harnesses and ecu from the 92 you can wire in. Granted, you would have to strip both cars to mroe or less the shell to do it..but hell, you can fix thing that may or not be broken, and polish / wax all the paint that nobody will ever see (probly the only way to get your car cleaner than Svxess's)
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
