Old 03-13-2006, 11:42 PM
hexadec0079's Avatar
hexadec0079 hexadec0079 is offline
Parts Breaker, Tire Waster
Send a message via AIM to hexadec0079
Help Asap!!!!!!!!
Oh wise sages of the Alcyone......
ok enough BS, I replaced my alternator (got lifetime warranty) a week ago. Alls fine til I go to the car wash and then a hour later my battery, ABS, etc. lights go off. Alternator cable loose, no biggie I think. Tighten it up and no lights, but it now sounds like a lawnmower and is sluggish. I'm thinking its a misfire, so I'll change the plugs tommorrow, I have no school or work, 12 hours to change 6 plugs... fun.
Also on an unrelated matter my tranny is slow in first til 2000rpm when cold, after a minute its fine, I'm thinking a flow problem preventing pressure buildup, so im gonna drop pan and change fluid.
1992 SVX- -Drivetrain by BUDFREAK-
Green, LS with spoiler, 157,000, ES Swaybar bushings, 9005/6 mod, 2.25' Dual Exhaust, Custom Grounding, Hyperwhite fogs, LED tails, 4.44s, custom Blitz intake, tranny cooler, thats about it, for now...
1997 Chevy 1500 -FOR SALE-
5.7 liter, Z71, 300hp+, still almost 20mpg
1986 Merkur XR4Ti -SOLD-
SVO Engine, T3 hybrid turbo, K&N, custom ducting, Initial D painted, 18psi, fastest car for under $1000, ever.
Old 03-13-2006, 11:43 PM
oh, also, are there any long term side effects of operating without A or C solenoids?
Thanks for all the help guys!
Old 03-13-2006, 11:57 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
You went to the car wash? Did you wash your engine?
Is your tranny still under warranty? If yes, or maybe not, you shld go back to check with the tranny shop.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 03-13-2006, 11:59 PM
If you are going to drop the pan, I would change the filter while you have it off. $30 or so. That will also help the pressure and flow.
Old 03-14-2006, 12:33 AM
no warranty on trans, more concerned with engine, thanks
Old 03-14-2006, 09:33 AM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
Alternator problems are notorious.
I went through 2 alternators last time, first replacement, from AutoZone, went bad within a week. Second, again, from AutoZone lasted 4 months.
After that I bought a 800CCA battery, an alternator from the Internet (yellow and grey box?), not an American (bald-eagle box) rebuilt and tightened and cleaned all the grounds and wires around the battery and alternator. It's been 8-10 months now and all is good. Also after I did this, everything seemed to run much much better and my lights and accessories are birghter.
Old 03-14-2006, 10:28 AM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Any codes?
It is very possible that you have fouled out a plug or two or six. With lack of power there may have not been enough electrical power to generate the high temp spark to burn the fuel properly.
I had a similar problem and was kickin the Left O2 sensor code but it was the timing belt had jumped a tooth on the right side. I reset the timing belt and all was fine.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 03-14-2006, 10:35 AM
no trouble codes, but im gonna go change plugs, i think that they are fouled b/c at idle its rough, shaking the engine, and at higher rpms its fine, so i agree with what you guys are saying, it makes sense.
Old 03-14-2006, 05:03 PM
I don't think it is the plugs, as they would break down under load, not at idle.
Why do you say "oh, also, are there any long term side effects of operating without A or C solenoids?"
If the A solenoid is not working, the line pressure will stay high all the time, the changes will be hard, especially when shifting into D first time from cold. Pump wear will be higher, engine power will be less.
The C Solenoid will not operate the AWD, if it is not working.
Old 03-15-2006, 08:16 AM
i am now suspicious of the exhaust instead of plugs. There was a minor leak before and i think that one donut may have blown out causing the sound and rough idle.
PS- anywhere to buy A and C solenoids, and can I replace them in my driveway or do I need to take it to a shop.
Old 03-15-2006, 10:43 AM
SVX-FF's Avatar
The A solenoid is on the top of the valve body, you will need to drop the valve body to replace. This will take a few hours or maybe a day.
The C solenoid in the rear section. This one is not that hard to replace can be done in about 4 to 6 hours.
You will need new fluid when you do either one so it makes sense to do both at the same time.
I have a C solenoid at my house and I will check today and see it I can get my old A solenoid too.
Steve
Are you in?
My Old Locker
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 03-15-2006, 02:04 PM
intelisevil's Avatar
<<<Alcyone
Before you replace your Solenoid A, check the transmission resistor located on the inner fender behind the battery. If it's bad, the TCU will often throw a code 11, "Duty solenoid A".
Dan
Old 03-15-2006, 05:17 PM
Why do you want to replace them?
Old 03-16-2006, 10:34 AM
ummm because they aren't working....
on a side note, its a exhaust leak, passenger side going into the main cat. Horrible sound and shakes the engine.
I patched it up with exhuast sealer goo until I get my exhaust parts in.
I'm going no cats into 2 sets of dual flowmasters (2 per side) with 2.5 inch tubing, and finish with quad tips, should sound good.
