Exhaust suggestions
Ok guys. Looking for some help here. Apparently my exhaust needs some work. Garage tells me I need the main pipe that includes the reonator. i replaced the small cats a year or so ago.
Garage said the main pipe I guess with resonator from Subaru is about $500CDN. It's a 1994 so it has the original mufflers which may not need replacement right now but I don't know how much longer I am going to get out of them. What do you guys recommend. 1) Paying the $500 and going with a patch job. 2) $1500 for a Stebro cat back system..... 3) some other cheaper option? thanks
94 SVX LSI 2001 LegacyGT (daughter's ride now) 2005 Legacy outback XT (wife's car) all stock and likely staying that way for now 1981 Datsun 280zxturbo summer toy |
Re: Exhaust suggestions
Just cut out the bad parts of exhaust and just replace with straight pipes in that section and put a universal resonater in. If you have access to a lift at all, its relatively easy otherwise just have a shop do it. But you don't need the OEM parts from Subaru.
Someone will post a link to what many have used I'm sure. And I wouldn't worry about the muffler, the one used in the SVX is kinda overkill and they don't seem to be a problem. |
Yea thanks Nate. I used a custom exhaust place to put in the two smaller CATS last year. I should probably take it there for some quotes. They said they could put a SS cat back system in for $700-$800 (without looking at it) so they could probably patch it with straight pipe for a whole lot less.
But that Stebro system sure looks nice. lol
The Aero AR25 is a great resonator. It runs about $60.00. AR25 resonator Here is a photo of it installed in my 96 Polo Verocious Motorsports also has a Magnaflow resonator 14416 It is a 4" round diameter, 14" long, (20" overall) for $67.00 or less http://www.performancepeddler.com/de...D=MAG14416#img .
1991 SVX L JDM |
Far cheaper than a stebro system. .
Ok looks nice. What's the sound like and what's the make. I'm heading down to a custom shop tomorrow to get some prices and would not mind a couple of names that people here have tried....
thanks
All We'll Drive sells a complete kit for a very reasonable price that is tried and trued. I know OT also will make a kit but prefers to do it there. Honestly, these boys know what they are doing and have come to the "right" set up via trial and error. Just as there are lots of gains to be made exhaust wise there are lots of losses just waiting to happen.
Yea I was just checking that kit out. Looks very good. I will likely be contacting them about it.... thanks
I have a good main pipe if you want to buy it. I'd assume shipping would be like $100. How's $25 + actual shipping sound?
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
Look at that fancy 3rd oxygen sensor!
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
The OEM catalytic converter has the 02 sensor mounted at the top of the cat towards the rear When I replaced the main cat with a Magnaflow one, the 02 sensor bung was mounted at the front of the cat. . Since the front of the cat is not the optimum place to get a good reading, I just plugged up that bung and welded one onto the exhaust pipe at the rear of the cat (as the original design) It gets a cleaner reading on emissions this way) Also installing it into the pipe makes it a lot easier to change. The original position was on the top of the cat, making it much harder to remove. ,
