Rear Side Marker Connector Question
Hey guys, I'm doing another LED conversion, with the rear side marker lights. I made the modules, yet I don't have a car to test them, so I'm lost as to which side is positive and which is negative on the connector. LEDs are polarized, so they only work one way. Here's a pic of the connector:
Does anyone want to test the connection with a multimeter, or tell me which pin is positive and negative? I would greatly appreciate it if someone could help me out on this. Thank You |
Re: Rear Side Marker Connector Question
Just match your connector to the matching plug with the wires.
It is a two wire plug. the black wire is ground and the pink wire is the hot wire. This ties directly into the existing tail light circuit, which uses the same two colors. You could just tap into the wires of your LED tail lights. The complete wiring schematics are in FSM 6-3, page 53. You can see it and download it HERE .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-11-2012 at 10:32 AM. |
I dont think he has a car to match it up with
That is what I found 2 mins ago Last edited by 92 SVX; 01-11-2012 at 10:32 AM. |
Yah, I don't have the rest of the harness, but this pic is helpful. Thank oyu!
here in New Zealand we did not get this as an option - our "side markers" are only "side reflectors", they do not come with marker holes in them, or the bulb & holders.
Just another quirk or option that I thought I would share with you - I have already converted mine to the USA type side marker, but would like a second spare set as a back-up (the bulbs + bulb holders + wiring connector + side marker). Can anyone help me - I have seen a few on ebay, but it is either one side or the other - normally without bulb connector & wiring connector. Thanks in advance Stephen in Auckland, NZ. surteess@xtra.co.nz |
