Old 05-18-2013, 05:06 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Speed sensitive steering feels backwards
at low speeds, my steering feels very heavy. when in moving at cruising speed it feels super light. I just installed a new rack a year ago rebuilt by an ebay vendor. could it be a problem with my install or did they reverse the assist levels?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-18-2013, 05:22 AM
Re: Speed sensitive steering feels backwards
I have the same issue with my '92. I was thinking it feels firm like I'm driving fast even at parking lot speed.
Old 05-18-2013, 11:51 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Did you check your power steering fluid? Do you hear the pump running?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 05-18-2013, 12:38 PM
I just replaced my power steering pump in my 92LSL with a used one and it feels the same way your describing..
Feels like there is no power steering while at idle, but at highway speed it is very easy to steer.
Completely opposite of how I would expect it to feel..
My old pump was shot and on that it was a crapshoot of when it would just suddenly go tight.
Like turn the wheel to move over 1 lane, and it is loose, then turn again the same way to over another lane and this time it would be heavy..
Which I found very dangerous, never knowing how much steering I had to give it..
At least now it is consistent..
Steering loosens up if it is moving at all, but if it is parked and I turn the wheel to move the tires to get out of a parking spot, it feels very hard to turn.
My rack was replaced by the previous owner in 2009. Power steering pump has been shot since I got it, so I have no idea what it should feel like..
Old 05-21-2013, 09:50 AM
Tim's Avatar
Tim Tim is offline
I hear the pump running. I do have some assist when not moving. It just feels like an excessive amount of assist while moving. I'll have to do some additional testing this weekend. Maybe they gave me an RPM sensitive rack instead of speed.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-21-2013, 05:06 PM
oab_au oab_au is offline
Tim that is what I would look at first. The pumps and the racks are different for the two types. You could have a mix of the two. Same for Blacky and Looking4SVX.
One Arm Bloke.
Tell it like it is!
Old 05-21-2013, 06:11 PM
Tim's Avatar
Tim Tim is offline
Thanks Harvey. Are there any identifiers? I recall when I put mine in there still was a solenoid to be plugged in just like the one I took out. I'm going to shift into neutral at cruising speeds to see if my level of assist changes.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 05-21-2013, 06:43 PM
Mine is definitely speed sensitive, I never changed it. I swapped the pump for a known working one of the same type. I'm thinking it may be a solenoid issue but there is no steering light illuminated.
Old 05-21-2013, 06:44 PM
Yes they all have that solenoid on the pump. It just tells the ECU when you are putting load on the pump to pick up the idle speed.
The Speed sensitivity pump puts out full pressure all the time.
The RPM type, has high pressure at low RPMs, decreases the pumps pressure, as the rpm goes up.
One Arm Bloke.
Tell it like it is!
Old 05-22-2013, 06:42 PM
Tim's Avatar
Tim Tim is offline
Sorry, I meant the rack had a solenoid on it.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
