Oil burning smell.?!?!
Hi all,
I keep getting this oil burning smell whenever I drive my car and as soon as it gets to normal driving temperatures. As far as I noticed there are no oil leaks anywhere under the car even when it is parked for very long times. Checked the engine oil and its level is full and same with tranny fluid and P/S fluid. At first I thought its just me getting that smell, but yesterday my sister is also complaining about the smell and she is not comfortable driving it as she is afraid whether it may strand her somewhere on the road. I have replaced cam seals, valve covers recently. Wht might be the problem ?? -Pavan |
Rear crank seal leak dropping onto the exhaust. That's my bet.
-Pavan |
check around power steering pump area. I have a tiny leak there that results in the smell, but it's so slow that you can't tell by monitoring level. Hasn't gone down noticably in over a month, but the leak is there.
But I can smell it in between the engine and firewall and also mostly on the driver's side... I am not sure if its the rear engine seal. How hard is it to replace it? _pavan
With a small leak, it would be enough to cause a stink when hitting the exhaust, but not enough to notice a decrees level.
I bought the car for my wife, but it's my new toy :-) |
The Crankcase is pressurized, {even more when running hard} and what you might be getting through the seal is an Oil Vapor instead. Alternators also have a similar smell when they get really hot, so check this too.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
