Old 07-27-2010, 08:44 AM
Maxo's Avatar
Maxo Maxo is offline
Need A/C Hose
Took my car in to get an a/c recharge and they said that my upper pressure hose was bad. The schrader valve was replaced and cross threaded at some point and now leaks. The shop indicated it couldn't really be fixed...
If someone has one let me know, my zip is 58078. I'd like to get it asap, the temp was in the 90's here yesterday!
Old 07-27-2010, 09:06 AM
Re: Need A/C Hose
I don't have one, but what year is your car. The hose is different across the years.
Old 07-27-2010, 09:52 AM
Maxo's Avatar
Re: Need A/C Hose
The car is a '92. Are you saying a later model a/c hose won't work?
Old 07-27-2010, 10:05 AM
Re: Need A/C Hose
A later model A/c hose would be preferable so that you could charge with r134a instead of R12 and an adapter.
Old 07-27-2010, 11:35 AM
Re: Need A/C Hose
Is that the only difference Mike?
Old 07-27-2010, 12:14 PM
Re: Need A/C Hose
I'm not sure what years are different, but there are different types of fittings used where the hose attaches to the firewall.
On my 92, it has a fitting held with a bolt, similar to the fitting on the compressor. Ben's 95 had a flare nut/compression type fitting on the firewall. I don't know if this coincided with the change from r-12 to r134??
Old 07-27-2010, 12:36 PM
Re: Need A/C Hose
Ah, I stand corrected. I was not aware of a difference at the firewall.
Old 07-27-2010, 12:37 PM
Re: Need A/C Hose
Maxo, I believe I have one of these hoses. LMK if you are still in need and I will check tonight for it.
Old 07-27-2010, 01:26 PM
Maxo's Avatar
Re: Need A/C Hose
Subaruparts doesn't have an a/c illustration for the '92,'93 years but I think my hose looks like the '94 and up illustrations (with just a bolt at the firewall).
@Mike621, I still need one.
Old 07-27-2010, 01:34 PM
Cam Cam is offline
Re: Need A/C Hose
IIRC, my lines are a flare nut and a fitting, and it is a '92. I will verify this when I get home and let you know.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 07-27-2010, 01:45 PM
Re: Need A/C Hose
If you have the bolt in style at the firewall, I do have one. I will unearth it tonight after I get home and check it.
Old 07-27-2010, 01:51 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: Need A/C Hose
A week ago I ordered the hose for a '92 from Subaruparts.com, and received it. Now it is no longer offered. Subarupartsforyou.com in CT only offers '93 and up.
Gene
Gene and Ben
Old 07-27-2010, 02:00 PM
Re: Need A/C Hose
Gene
Gene, that does sound somewhat likely, unfortunately.
However, I always check with my local dealer and with Annapolis Subaru before I believe that it is unavailable.
Old 07-27-2010, 03:13 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: Need A/C Hose
I would think that you could take your old one to a hydro shop and have one made using your old fittings. Wouldn't see why they couldn't make one.
Old 07-28-2010, 09:00 AM
Maxo's Avatar
Re: Need A/C Hose
Mike, I just verified that I do have the hose that is bolted to the firewall. Please PM me with price to 58078 if you find one.
It doesn't seem that it would be too hard to fab a hose for this application, for a specialty shop anyway...
I'm probably going to need new o-rings, what materials can I not use? There's a place nearby that sell a wide variety of these and there's always the dealership.
