Need A/C Hose
Took my car in to get an a/c recharge and they said that my upper pressure hose was bad. The schrader valve was replaced and cross threaded at some point and now leaks. The shop indicated it couldn't really be fixed...
If someone has one let me know, my zip is 58078. I'd like to get it asap, the temp was in the 90's here yesterday! |
Re: Need A/C Hose
I don't have one, but what year is your car. The hose is different across the years.
Re: Need A/C Hose
The car is a '92. Are you saying a later model a/c hose won't work?
Re: Need A/C Hose
A later model A/c hose would be preferable so that you could charge with r134a instead of R12 and an adapter.
1991 SVX L JDM |
Re: Need A/C Hose
Is that the only difference Mike?
Re: Need A/C Hose
I'm not sure what years are different, but there are different types of fittings used where the hose attaches to the firewall.
On my 92, it has a fitting held with a bolt, similar to the fitting on the compressor. Ben's 95 had a flare nut/compression type fitting on the firewall. I don't know if this coincided with the change from r-12 to r134??
Re: Need A/C Hose
1991 SVX L JDM |
Re: Need A/C Hose
Maxo, I believe I have one of these hoses. LMK if you are still in need and I will check tonight for it.
1991 SVX L JDM |
Re: Need A/C Hose
Subaruparts doesn't have an a/c illustration for the '92,'93 years but I think my hose looks like the '94 and up illustrations (with just a bolt at the firewall).
@Mike621, I still need one. |
Re: Need A/C Hose
IIRC, my lines are a flare nut and a fitting, and it is a '92. I will verify this when I get home and let you know.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
Re: Need A/C Hose
If you have the bolt in style at the firewall, I do have one. I will unearth it tonight after I get home and check it.
1991 SVX L JDM |
Re: Need A/C Hose
A week ago I ordered the hose for a '92 from Subaruparts.com, and received it. Now it is no longer offered. Subarupartsforyou.com in CT only offers '93 and up.
Gene
Re: Need A/C Hose
However, I always check with my local dealer and with Annapolis Subaru before I believe that it is unavailable.
1991 SVX L JDM |
Re: Need A/C Hose
I would think that you could take your old one to a hydro shop and have one made using your old fittings. Wouldn't see why they couldn't make one.
Re: Need A/C Hose
Mike, I just verified that I do have the hose that is bolted to the firewall. Please PM me with price to 58078 if you find one.
It doesn't seem that it would be too hard to fab a hose for this application, for a specialty shop anyway... I'm probably going to need new o-rings, what materials can I not use? There's a place nearby that sell a wide variety of these and there's always the dealership. |
Thread Tools | |
Display Modes | Rate This Thread |
