Old 05-10-2010, 10:47 AM
Re: 1992 LS-L Full part out (No Drivetrain)
Originally Posted by blackozone View Post
Incredibly so, yes.
It's almost like a liquid, paint-on aluminum. To patch all the holes in the floorboard he put some strips of painter's tape over them and painted the POR-15 on. Once it dried and cured, it was like a solid piece of metal floorboard (albeit pretty thin).
He layered that a few times on it and it became very solid.
Also, for some of the rust spots on the body he applied the POR-15 there. After it did it's thing and cured, he hit the rust spots with a wire wheel to bring it back down to metal again. The POR-15 went through the rust and turned it all black. As I understand it, the material can penetrate and neautralize rust completely, and it appears to do a bang-up job of it. I was severely impressed.
Thanks, I have a few small out of sight spots I may try it on.
Old 05-10-2010, 12:43 PM
blackozone blackozone is offline
Wheel caps have been sold and shipped to NeedForSpeed.
NeedForSpeed, sir: I cannot PM you the tracking number, your inbox is full.
Old 05-10-2010, 02:00 PM
Maxo's Avatar
Maxo Maxo is offline
What about the MAF or ECU? Does the car still have those?
Old 05-10-2010, 03:35 PM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
^ im sure both have been used on idgets swap, his wiring guy is the same as my wiring guy
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 05-10-2010, 03:42 PM
Correct, the MAF and ECU are being used for the 3.3RS project.
Old 05-19-2010, 05:01 PM
PaulCa13 PaulCa13 is offline
Send a message via Yahoo to PaulCa13
Hello,
There are a couple of piddling little things I need from a gray interior. If it's worth your time, I'd like to know if you have:
- Trunk/gas door release-handle unit
- Pointy, yellow fasteners that hold the console side trim (need 2-3)
- Rear-deck speaker covers (if they're not cracked)
If you'd like to sell any or all of this, just let me know. You can get me at paulca13@yahoo.com
Thanks,
Paul
