#76
Re: Shaved door handles
Impressive so far.
I'm listening.
1991 SVX L JDM |
#77
There isn't anything to it, there are a couple options, Autoloc makes one specific for this purpose, but it is about $40. Since whatever I do is going to be covered by the panels in the trunk, I can cheat a little. I'm going to take any non-power antenna from something in the junkyard and attach it to the underside of the trunk lid. If reception isn't good enough, I can always add an amplifier.
Just a note for anyone else considering shaving the antenna, plugging the hole in the top of the quarter that the antenna came through is necessary, I'm just going to use a rubber plug like the ones already filling holes in that area under the trim. Last edited by Elliott; 06-24-2009 at 10:08 PM. |
#78
I assume with all these visual mods you're going more for the show car look as opposed to practicality, but I'm still left wondering about the washer nozzles. Are you replacing them with a wiper arm mounted sprayer, or just praying it won't rain? I've been especially curious lately though as it seems Colorado has very suddenly been moved to the middle of some strange Central American rainforest... but with tornadoes.
92 LS-L, Ebony Pearl, 160k miles, sitting in the hospital waiting room hoping for a miracle 06 Hyundai Sonata GLS, 77K miles |
#79
You should fill in the emblem holes while your at it. It looks better with the shaved handles and no washers.
#80
I'll either put the washers on the wiper arms or hide them in the cowl. Not really a concern, the only time I need them is in the spring when the pollen is really bad. Nothing I am doing is going to really be impractical, everything is just kinda being relocated. The only thing I have truly eliminated is the door locks, which are kinda useless without door handles. Quote:
EDIT: Emblem holes are gone. Last edited by Elliott; 06-25-2009 at 05:41 PM. |
#81
so with all the poppers and all that added in weight how much crap will need to be added to be able to pop the doors with a button???
I don't know if I for sure would want to remove my handles or the locks, but as far as the antenna and installing poppers I'd totally be interested. Also, when you talk about the trunk are you talking about the stock trunk or a replica you made or will make??? I'd definitely be interested in a lighter version of the trunk and trunk poppers. So when it's all said and done, the entire install how much do you usually charge customers to do this kind of body work??? Also one more question, on the video the door barely pops open is that as far as it will pop when it's all said and done or will it pop a bit further? Is it possible when combining with say for example a lambo door kit such gt factory you could get the doors to completely open??? just curious. Last edited by Johnybeas; 07-08-2009 at 12:20 PM. |
#82
what about making the rocker moulding 1 piece rather than 2?
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
#83
Not really much point in it, but sure, it could be glued together and finished out. We have talked about making some custom fiberglass ones though. Last edited by Elliott; 07-08-2009 at 10:37 PM. |
#84
how much would it be just for the solenoid for the trunk and the kit? would someone be able to install this with just a how too, or is it quite complicated? I mean I did my own 5spd conversion and have done most of the rest of my mods myself. This couldn't be much harder right???
#85
It is pretty basic wiring, if you are using a channel without an internal relay, you'll need an external SPST relay, since the control box will fry if you try to pull more than 250ma. Installing the solenoid isn't hard, just make it pull the same thing the cable pulls, unless you did what I did and removed the lock, then make it pull what the lock used to pull. Last edited by Elliott; 07-09-2009 at 01:09 PM. |
#86
Even the Remote Window Controls (to roll the windows up and down from remote) was very easy to install.
-Roger H. | Website - nsm484.com | Facebook - Roger Harvey | Twitter - nsm484 | Personal Locker 2002 Mitsubishi Lancer OZ Rally [Nori] 1996 LSi Polo Green [Calista] - 18" Konig Incident's - Lived for awhile Now Selling 1992 LSL Dark Teal [Yori] (Rear Ended, Donor to Calista, and now gone) 1992 LSL Ebony Mica (Sold to svxcuseme) |
#87
I never even bothered hooking up my antenna when I installed my nav unit. The only choices around here are Country and the Jesus station. I can't live without XM.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
#88
For right now, I listen to the wind and a 232 I6 engine. |
#89
there is a good oldies station in Meadville. WMVL
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
#90
Do i seem like an "oldies" guy to you?
