Old 04-05-2006, 03:36 PM
danyvaly danyvaly is offline
advice on over heating
the water pump leaked and the car over heated for two minutes, i immediately turn the engine off. It happened 4 times (always turning the engine off before it started to overheat) before i could bring it for repair.
The engine is perfect, my question is:
are the gaskets going to break soon?
thanks
Old 04-05-2006, 03:50 PM
Hard to say. Best to replace the pump, etc and go from there.
Old 04-05-2006, 04:14 PM
replaced water pump already
i already replaced the water pump, and i drove the car for 400 miles. thanks for response
Old 04-05-2006, 04:22 PM
Drive it like it is. If something happens deal with it then.
Old 04-10-2006, 01:21 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
How is it running now? When they changed your water pump, did they flush your radiator and change your thermostat as well?
How is your AC working? I know Miami is getting hotter.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 04-10-2006, 02:38 PM
I would see if the fans are kicking on while running that could be a cause. ALso the thermostat, but that should of been changed with the waterpump i would imagine. Is the radiator or condensor clogged or plugged? What color is the fluid? Just some suggestions to give ya
Old 04-10-2006, 05:14 PM
spinn360's Avatar
spinn360 spinn360 is offline
I dont think he still has a heating prob, he just wanted to know if something else is going to go because of the previous overheating.
1989 Subaru XT6 130k
1992 Subaru SVX 120k
1993 Ford Probe 30mpg 213k
1989 Subaru XT6 150k
All good and running
Old 04-12-2006, 02:08 PM
thanks spin for the imput
I don't have a heating problem. I just want to get some input from experts like you. the engine is running perfect. i'm just concerned of the long term consequences. i spoke to two mechanics and told me as long as the gaskets didn't blow on the spot the engine is fine. but wanted to double check on svx mb... thanks
Old 04-12-2006, 09:23 PM
From what you have posted, it would appear that the engine did not overheat to the point whereby, there was a different level of expansion/contraction between heads and block, as would be required to cause the gaskets to be damaged.
All things considered, you handled the problem effectively and you should relax and enjoy !
Old 04-13-2006, 04:06 PM
spinn360's Avatar
I agree with trevor. Sounds like you got lucky. so relax, or dont, your choice.
