Old 02-02-2005, 06:24 AM
96svxer
I was only refering the problem below:
Oh no. I meant it's always the ECU if the seatbelts only work with the keys in the ignition
It seams to be the numebr one seatbelt problem of svx';s
Kuoh....I had the same problem you did. Seatbelt would get jammed everytime and a nice hit would break it loose. I ripped apart the car and it turned out the wire cable that drives the seatbelt back and forth on the track became slightly un-twisted which caused the seatbelt to jam. I re-twisted it with a pair of pliers and re-assemled and it has worked flawlessly for over a year now. Might want to give it a try.
Old 02-02-2005, 08:54 AM
alia176 alia176 is offline
One of these days I'm going to convert the whole system to a manual type! That way, I don't have to keep reminding my passenger to put the lap belt on!
Ali
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 03-31-2005, 07:17 PM
zollinw
Fixed
As a final follow up, I purchased a used control module from a member here about a month ago. I finally installed it tonight. Success! The belt is working normally now. Thanks for everyone's help. Bill Z
Old 04-01-2005, 05:22 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Can you please give some detail where the module is and how to replace it? My seat belts are disconnected, and when I plug them back on the light and sound indicator goes off. Thanks.
Old 04-01-2005, 11:25 AM
96svxer
Module is in the trunk under the rear wiper. Remove the trunk plastic and its a silver box with two very large wire looms comming out of it.
