Old 10-08-2004, 06:35 PM
ilsegretosvx
leakey steering rack replace or fix
dang car, I fix a cracked hose that was dripping coolant on the exhuast then it starts smoking from another leak. I get under the car and it looks like ps fluid is dripping on the same damn place. Is this a quick fix thing or replace. Im going to have to buy another one just to have one to drive while the other is in the shop....
Old 10-08-2004, 07:31 PM
There is another possible problem instead of a leaky rack. It could be your O-Ring is leaking. Check the area around the reservoir to see if it is leaking under it and then dripping down on the rack. That is usually the problem. Look in the How-To Documents for the directions on changing it. Hope you find that this is the problem. Good Luck
Old 10-08-2004, 09:36 PM
ilsegretosvx
well it looks like I will be under the car again manana. Are the o-rings an universal type or exclusive Subie part?
Old 10-09-2004, 10:53 AM
You can buy them almost anywhere. Just get the same size.
Old 10-23-2004, 04:54 PM
ilsegretosvx
Have the o-ring in hand and started to trace the leak only to find out it is the ps pressure line. I called the local Subie dealership and nearly crapped my pants.... $127 for that freakin hose. I am on my way to a new car by replacing piece by piece on the SVX, but it will be worth it
Old 10-23-2004, 05:28 PM
NiftySVX NiftySVX is offline
P/S issues
I also have a leaking rack on my 92. The rack is rebuildable, but it requires special tools only a subaru dealer would have. That isn't bad for that hose, I have seen some on toyotas cost as much as $400. The resivoir sits on top of the pump, I don't see how it would run down to the area you describe, unless you are talking about the pump and not the rack.
NiftySVX
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
