Trouble Starting
Having trouble starting the new rebuilt motor. I'm only running about 150 rpms at startup. Seems a bit low. Any idea what you guys are running normally at starter crankup?
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
Re: Trouble Starting
Yes. I've been concerned about the bearing resistance. The builder thinks it is perfect, but the starting revs on the motor are about 150 rpm which seems low??? Any idea what yours are? I should still be able to get my cylinders to fire thought. Very annoying. The valves seem tight. The cylinders pull and push air properly. I'm making good spark. Fuel is good. I'm stumped.
Giving money and power to government is like giving whiskey and car keys to teenage boys. – P.J. O'Rourke |
I am at a loss as to what it could be, but the manual indicates that normal idle rpm is about 700 +/- 50.
The motor was tested before it was sent to me. judging from the amount of vacuum it pulled when I manually turned the motor, I think everything is sealing up pretty well. Even if the compression is off a bit it should still start.
The RPM at 700 is idle. I'm asking for the rpm when you are just running the starter and the engine does not start. I guess you would either have to have a problem with your car or disconnect the fuel pump to test this. I just thought someone on this forum would know off the top of their head.
Are you absolutely positive that you plugged everything in when the engine went in the car? Double check the connectors are all mated. Have you verified fuel and spark?
I also hand cranked the motor a bit after installing the timing belt, with the intakes and exhaust taped off. Lots of vacuum on the intake and pressure at the exhaust. poped the tape every time. One think I'm thinking that it might be is flooding. I may drop the rail pressure and try again. My plugs did not seem fuel fouled though. But to be honest they did not even look like they fired.
I still just really need to know about how fast this engine rotates with the starter and no firing. Any help would be appreciated.
As long as it has a compression cycle, and there is fuel in there, and the spark arrives at the right time, it will fire. If it is not rotating fast enough, it will just kickback. You say it has spark and the injectors are firing, we assume that the timing is right. I would try starting it for a few times, then stop pull a plug, see if it is wet. If it is not wet, there is no fuel injecting. If it is wet then there is either no spark at the right time, none at all, or the fuel is not burnable. So I would check that the plug is sparking at the right time, and that the fuel that is being injected, is not too old. Harvey.
Figured it out. My valves seem to be sticking open. May be a problem with a recent cam grind I had done, and the intake valves not seating completely. Intake stroke seems very tight, so I think the exhausts are good
Ug!!! Talking to Mike to see what we need to do about the cams.
Haven't pulled the cams yet. Mike seems to think that may lifters need to be rebuilt. We'll see. Once I pull the lifters, I'll check to see if the valves are holding pressure. If they are, then it is just a matter of determining if the lifters have enough travel with the larger base circle of the cams. Getting the lifters rebuilt will only cost a bit over $120. It is just the time to pull everything apart including the timing belts and remove all of this crap. Seems like this is never ending. If the lifters don't squeeze enough or the valves to seal completely, I'm going to be pissed. Bottom line, I hope this is it. This project has really worn on me.
