Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #31
Old 04-25-2007, 10:59 AM
longassname's Avatar
Just some dude.
I haven't reworked the entry pages to showcase that we have the engine components available now but I have at least added the rudimentary product pages for them so you can order them.
http://www.ecutune.com/svx_engine.htm
Old 04-27-2007, 06:01 AM
cdigerlando cdigerlando is offline
Measurements
Originally Posted by longassname
The pistons themselves are not 97mm. The pistons are for a 97mm bore which is just a light hone on the factory cyllinders. The pistons are 96.9137mm at the guage point.
Just remember to hone your cyllinders to 3.819" = 97mm. The ring set includes instructions on the hone as far as grits to be used and what not though it is pretty standard stuff.
Thanks. I'll check the instructions tonight. Just got the pistons last night. I'm going to look them over real good tonight. I looked at two of them already. They are beautiful. CP really does a good job. The squish area is nice. It's not a big deviation from what we already have, so there should be no suprizes. Looks like you thought of everything on these.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 04-27-2007, 06:14 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Guys, these are INCREDIBLE!!!! I cant wait to see what all this stuff can do. Congrats guys and great job mike. P.S.
Cdiger, shoot me an email, we should talk about boost levels for you, and when are you gonna let me put in that IC
~Phil
Old 04-27-2007, 12:18 PM
with some luck mine will be here today... but probobly have to wait till monday. I just ordered the pieces I will need to build my enormous headers so at least my exhaust will be ready for this motor.(Need software to run dual MAF's soon)
Old 04-30-2007, 09:27 AM
Got em today These are the prettiest pistons I have even laid my hands on... Mike, great job getting these done and lets hope we can make some serious power w/ our builds
Old 04-30-2007, 10:59 AM
mikecg's Avatar
mikecg mikecg is offline
Got mine yesterday afternoon.
Old 04-30-2007, 01:06 PM
sicksubie's Avatar
I think that I do not even have to say anything else...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 04-30-2007, 01:12 PM
Pistons
So Mike, when do you plan on starting to fit the pistons and filing all of the ring clearances? I'm sure you will let us know how it goes.
Chuck D.
Old 04-30-2007, 05:50 PM
Just some dude.
There are very detailed instructions for the rings in the ring specification sheet inside the box of rings.
I don't have a time table for putting my engine together. I'm anxious to geet it done too but I have a lot on my plate and there is still only one of me.
Old 05-05-2007, 12:32 AM
92SVXMan's Avatar
92SVXMan 92SVXMan is offline
Thumbs up Names and e-mail addresses
I have started saving now where do I go to get more info, so we can check them out ourselfs.
Thanks for showing us some great part for a engine rebuild, which I am now planning.
_______________
92svxman & Freida the co-pilot.
First 92 Claret(flat color,IMHO)
Two 92 Teal(much nicer color)
5 Speed pending, from 93 Legacy Turbo
4.11 Tranny/rear diff. May go for 3.90
Claret 145K
Underdrive Pulley from Newbies2005
New timing belt
new radiator
new water pump
new timing belt cover
New headlights and harness
Replaced exhaust (with stock)
Life on the road who could ask for more
Old 05-05-2007, 09:46 AM
Just some dude.
or to go directly to the pistons and nothing but the pistons:
http://www.ecutune.com/svx_pistons.htm
Old 05-05-2007, 11:04 AM
Just some dude.
He means new bearings of course. Don't anybody start thinking about popping new pistons/rings in without cracking open the block. I am hearing more and more stories of main bearing failure but not because of increased power outputs. People are just wearing them out. For a few years now people have been swapping in engines from the later model SVXii with lower miles when their engines have gone out. Now we are basically out of lower miles SVXii engines and it's time for us all to start getting familiar with building the EG33.
As the front runner in this I can share some warnings that may help others, particullary those who don't want to buy these pistons. The availability of the factory pistons is poor. I've been waiting months now for a right A piston. If you want to stay stock do yourself a favor and rebuild your engine before it fails so you can re-use your pistons and just re-ring them.
Originally Posted by TomsSVX
I think the rods and bearing are good to at least 500 hp. Just don't **** it up
tom
Old 05-05-2007, 12:02 PM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Tom are you going to swap out the blower for a turbo? I don't think there's a pulley small enough for 20-30psi on your current setup..?
Brian
Old 05-05-2007, 01:02 PM
I'm not sure which blower Tom is using, but there are physical limits to what even the big blowers can produce.
The twin screw model, which Tom has, I think, this is better for handling high boost. That's why Mike picked it in the first place. Even so, regardless of what small pulley you use to spin it up, beyond a certain boost level it will be subject to leaking pressure back through the rotors.
I'm not sure what max boost is with Whipples, but I'm thinking maybe 25 lbs.
Even with 8.5 CR and these new pistons, if you go to high boost without charge cooling, the in-cylinder temperatures will be too high. So, if high boost high horsepower is planned, it will have to be done with cooling. I do expect anyone building a high horsepower engine will already be planning this.
[Actually, guys, I wonder if it would be possible to boost the EG33 using the supercharger + turbocharger method Volkswagen use with their hi-tech 1.4 Fsi engine? That would be a worthwhile mod. ]
Old 05-05-2007, 01:24 PM
Just some dude.
I don't believe Tom is shooting for those kind of boost pressures. Just because the pistons are designed to handle those kind of boost pressures doesn't mean it's suddenly and magically feasible to start driving around town at 35 psi on pump gas.
The supercharger systems I put out last year are not designed to run that kind of boost either. They are not aftercooled or easily aftercoolerable; that means they are limited to the 12ish psi which Tom and SickSubie already have pullies for.
