Problem with the hood.
ok, this is a pretty simple dilemma. THe hood won't stay up. Not a huge deal, but it makes checking under the thing a pain, especially if im not at home. Is there an easy fix to this?
I personally hate the hood we have because it has nothing to hold it up. Mine stays up fine in the summer but in the winter it will never stay up. havent found a fix for this yet.
Re: Problem with the hood.
I used a metal pole about 40" long before I got new struts.
I've seen someone (Nubs iirc) use a short length of rubber hose with a slit in it, slipped over the shiney part of the strut.
Dave - 03 Baja - 92 SVX - 86 Brat - 08 OB 3.0 Last edited by Hocrest; 08-04-2004 at 09:20 PM. |
There are sources for the Subaru struts, but I don't know of anyone who has got after market ones to work. You can buy used ones, but you get what you pay for. If you need part numbers, let me know.
I got after market lifters on my car, but I don't have the stock hood on my car.
I don't use the struts on my Carbon Fiber Hood. I use a metal rod.
Show us your special part !!!
Figured the link would have worked. It's called a universal lift support clamp. Here's a pic.
i double clicked on the underlined word these
it showed the picture and displayed other data thanks dwayn
DWAYN |
hood struts
I used a pair of struts from the junkyard that I paid $5 each. (make sure they are still good before you buy them) They only required a very minor modification to make fit just right.
They were from a hood on a 1990? Buick Riviera. (Be sure and prop up the hood prior to removal. Remove and keep the retainer clip locks when you pop off the struts from the doner vehicle) All I had to do was drill an appropriate sized hole thru the plastic ball end that mounts to the body and run the origional bolt thru. Be sure and re-use the bolt bushing at that mounting point. As for the other end, spread open the retainer clip and set it almost into the slots they came out of. Then pop that end onto the swivle ball and seat the locking clip into place. Works as good or better than OEM. I think the Buick hood might have been a little heavier than the SVX hood, and is made to hold a heavier load. I'm still looking for a similar set for my trunk lid. morris |
