Help Urgent My SVX stopped on its own. F Wh Locked.
Hi All
I was driving and all of the sudden my SVX stopped on its own, like I stepped on the brakes crazy. Tire burning smell and all... Only I didn't even touched the brake pedal. It was 1Am in the morning, so I towed it to my apartment and during the process could see the front wheels are locked up. I need to acertain whether this is brake or transmission issue. And if brake problem, I would like to know whether such stop would cause any harm to other things like transmission, since if tranny is demaged I can't keep my car.... I have replaced some transmission fluid yesterday so I checked ATF level and it seems overfilled. I've been driving w/ FWD fuse in since I have minor binding problem. But I didn't notice any tranny issue otherwise and shift has been smooth. No sign of any leak on the bottom or engin bay. The brake fluid looks really dark and bad and front brake has not been serviced for a while. Tow truck driver said it could be ABS fuse, but fuse seems fine. Thanks! |
Re: Help Urgent My SVX stopped on its own. F Wh Locked.
It's not an ABS fuse...
when it was getting pulled onto the flatbed, were the front wheels turning a few inches then springing back? On both sides? Have you tried to drive it this morning, does it move at all? How long have you been in FWD, how often did the front wheels slip/spin when taking off? Was the engine running when you checked the ATF? It needs to be to get an accurate reading.
Thanks for the reply.
No. Quote:
ANy opinion would be appreciated! |
Answer me this and I'll have a better idea... It will either feel like a lot of resistance, then slowly start to give. Or most likely it will start to move freely for an inch or so, then fell like your trying to drive up onto a curb and not go any further. If your able to safely jack up the front so both wheels are off the ground try to spin the wheels by hand.
Sorry I haven't tried it yet in the morning.
I will wait for your reply and then go out to try starting again... |
O.K. I just tried to start and move the car.
Gear in Park, start the engine with brake on, then move to Drive. When I release the brake after that, I feel slight movement forward like inchs then stops and may be bounce back slightly like wheels are blocked by curb. But no responce to the engine reving at all. Hocrest let me know what you think... Opinion from else would also be appreciated. Thanks! |
