SVX longevity
I’m curious as to what I might expect for longevity for my SVX (a ‘92 with 140,000 miles - replaced rear wheel bearings @ 118K, rebuilt transmission @ about 100K). If enough people post the year of their SVX, the number of miles on it and a list of the major repairs required (and when) I’ll attempt to summarize the data and post the results. Anyone interested?
1992 ls-l
133k miles front struts replaced power antenna door lock motors lock cylinder on pass door timing belt covers all done in oct 04 at about 119k miles no major work like tranny or engine done that i know about. runs great and 95% of the time shifts great too things that are broke and not fixed yet trunk lock cylinder alarm front struts shot again |
92 liquid silver.
105,000 miles body is scratchified and door dinged regular oil changes with pure synthetic replaced air and oil filters regularly ( K&N both) timing belt changed at intervals ORIGINAL tranny, with aftermarket cooler and external filter STILL GETS ALL FOUR LOOSE ON HAIRPINS! yup, with a lotta bit of TLC and a pocketbook to match, an SVX can live FOREVER! mine will! |
My worst fear is mine sits to long and that will cause me problems , but other then brakes and trans gasket replaced runs like new! So far Oh yeah I did the bearings ,It wasn't needed yet, but it was in for some other minor work and I'm glad I did it . Car drives like new again ( the other work was the leaking tranny gasket and I had new drilled and slotted rotors put on so I told them to do the bearings ! It was not because I was having a problem , Better safe then sorry) YES I did the pads too
92 with approx 170k miles and the original tranny as far as I'm aware still going strong. with New rotors all around.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I think the biggest factor affecting the lifespan of the SVX is the contents of the owner's wallet.
My car came with the warranty service booklet showing dated and stamped entries by the dealership at recommended intervals up through 90,000+ miles. I don't think the work I've done (from 104,000) is unreasonable given the mileage and vintage, and fully expect it should soldier-on to 200,000 miles and beyond. dcb |
I have 225K (and climbing) on my daily driver. My tranny stories are well chronicled on this and the yahoo forums (which I frequented prior to this site opening). Long story, but, it wasn't the trans' fault in my case. I've had one wheel bearing replaced (R/R) and I think my L/R is beginning to whine a little. [Whispering while knocking wood] No other major repairs.
I have 235K miles on mine and in the last 5 years (since i've gotten it) I know its had this done:
Transmission replaced with a 97 model tranny Tranny cooler 2 timing belts 2 water pumps valve cover seals cam seals crank pulley (old one split apart) new rotors steel braided brake lines ECU crush mod (not really a replacement but i listed it anyway) new front struts new spark plugs (about to be done again) custom exhaust w/new cats replaced antenna 4 sets of tires & two radios Those are all the things i replaced my self. When i totalled it (right after i bought it, here is what i had done..it had about 115K miles on it then) New bront body parts (hood, fenders & bumper) radiator new ABS system new condensor new evaporator new headlights (and middle grill piece) front turn signals frame straightened (13 hours on a frame machine)
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
92 LS-L. Currently 85500 miles.
- Tranny rebuilt, front axles replaced, powersteering pump seal fixed, and driver side power window switch/window rubber stopper replaced, all at around 75000 miles. - Original front rotors warped, replaced all 4 corners with aftermarket at around 84000 miles. - Oil disptick 'o' ring worn, making the dipstick popout randomly (that sounds perverted). Put new 'o' ring at around 85000 miles. That's about it for "major issues". Okay, so most weren't really major. By the way, the tranny wasn't slipping before the rebuild, it was just having issues going into reverse and sometimes it would "flare" during shifts. The gears, etc, were in great shape when they opened her up for the rebuild. The 4EAT is actually a very strong transmission, it just tends to run hotter than most and its casing design isn't optimal for heat decipation. This can lead to premature wear and/or failure of internal components. I thought I'd mention this because dispite having to be rebuilt, I was amazed about how great of shape the items that matter were.
Eddie '92 SVX LS-L (For Sale! Info and link to pics... ) #9536 blt. 4/92 (late boomer '92) '01 Audi S4 (2.7L Twin Turbo - 6MT) |
