Completely dead SVX?
Yesterday evening, my 96 svx lsi completely died...electrically speaking of course. Nothing worked...no headlights, horn, cruise light, turning the ignition resulted in nothing. However, the security light and the hazards did work.
My initial thought is that somehow the car's stock security system disabled itself, but I am lost as to what and how that occurred (if that was the case). any thoughts? thanks, chris |
Re: Completely dead SVX?
I strongly suspect the fusible link in the main fuse box.
Power to the hazard and security system circuits are supplied from fuses directly connected to the battery and do not involve the fusible link, which is in circuit with most of the other electrical equipment. The fusible link is located in the main fuse box in the engine compartment and consists of a short piece of wire covered with heat-resistant material and connected by push-on connectors on each end. Corrosion can also be a problem. Just pull it and connect a meter across both ends to see if it has failed I keep 4 or 5 on hand just in case, as emergency replacements are not available outside of the dealer. The P/N is 82301PA000 and they are about $4.69 each. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 04-04-2010 at 06:42 AM. |
Chris,
Check the link for continuity and condition. If you need one send me your address and I will send one out to you on Monday (although your dealer could get you one almost as quickly)
Thank you very much John. I will be able to pick one up Monday and will report back with results. Thanks again.
I'm sure John's info is correct, but it wouldn't hurt to poke around before buying anything. Check all of the connections at your battery terminals and make sure they are clean and tight.
