Need quick transmission pan help!
Hey there!
Replacing my trans filter and pan gasket. What is the proper procedure and pan torque specs to re-install the pan and gasket? Do the pan bolts need to be installed like wheel lugs; in a criss-cross motion? While we're at it, what is the proper way to clear the trans cooler lines running to the radiator? Thanks in advance!
'92 Pearl White LS-L Touring SOLD 4.44 Swap, trans cooler, trans filter, trans temp gauge Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines Raxles front axles |
Torque them 1/2 way, then torque all the way to spec. I've never done a total cross pattern but have just done enough initially to hold it up. Definately don't gunk it up with sealant if you can help it. It'll run into the fluid and get clogged in stuff.
Sealant? Sorry, I'm not a mechanic by any stretch...I've got the gasket for it, do I need sealant as well? Thanks!
No sealant unless you have to. Don't be suprised if you end up putting it on a couple times before you get it to not be leaking.
Ok, cool.
Before I start this, here's what my car is doing. * Difficult to get into Reverse when hot * Whines (relative to vehicle speed and only when under load) at hwy speeds * Speedometer jumps all over, seems to be correct only when under load There is no "AT temp" light and the dipstick actually reads WAY over full now...Used to leak a little, now doesn't leak a drop. The fluid on the dipstick doesn't smell bad and is bright pink. What the hell is going on?!
The AT light on a Subie tranny only comes on at like 280 degrees. You've long cooked your tranny prior to then!
Having a tranny overfilled is VERY BAD for the operation of the tranny so that might be causing some of your issues.
