Ride hight?
OK, who has the right specs and measuring points for the ride hight?
I've looked in three different places and found three different specs. It looks like the measuring points are from the center of the wheel to the bottom of the wheel wheel arch. Right now I measure 14" in the front and 12 1/2" in the rear. So how low am I really from "stock"?
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
I'll check the alignment machine tomorrow morning, it should have them listed.
Yeah, I looked on Alldata, a Motor manual, and in Chilton manual and got different numbers from each one.
Mike.... 8/96......Vin 100109 1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!! Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines. 1997 SUS Legacy,finally got the engine in after a year!! My Locker www.myspace.com/devilhornz |
Yeah, lemme know what you guys find. I think I would trust the factory manule the most.
And on the same note, what are some of you other guys running in ride hight? Stock and modded?
I will let u know on Tuesday
Tom |
