Rotors and pads
Just about since day 1, my SVX has had brake judder due to "warped" front rotors. It was minor enough that I was going to wait until the pads were worn and swap everything out then. Since my son will be driving the car, I am going to do it now. I have decided on StopTech (Centric) cryogenically treated slotted rotors. The pads are a tougher decision. Street pads that are more likely to deposit crap on the rotors are better at cold stops than performance or racing pads, which are less likely to deposit crap on the rotors. What seems to be a potentially good compromise are the EBC Ultimax pads (Black). They are similar composition to OEM and supposedly have good cold bite. But they also claim to have done something with the composition to avoid depositing crap on the rotors and getting judder. Has anyone tried them?
Re: Rotors and pads
Don't use slotted rotors, just use blanks. Centric is very good for rotors. I know stoptech street pads are very good, and the hawk HPS or performance ceramic pads are very good street able pads. I don't have personal experience with the EBC pads so I can't comment on those.
Re: Rotors and pads
The logic on the rotors has to do with avoiding judder. Slotted rotors stay cooler and keep the pads cooler. Cryo treating makes the rotors more durable so they can stand up to more abrasive pads without wearing too fast and potentially cracking or warping over time. There is some argument over cross drilling versus slotting for keeping brakes cool but there aren't any cryo treated cross drilled options nor are there cryo treated solids. For avoiding judder and long term durability, these are the best rotors I could find.
The Hawk HPS pads were my next choice. But they are a PITA to bed in and I read some concerns over bite when cold.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 08-20-2014 at 05:23 AM. |
Re: Rotors and pads
Just a FYI, the multi-slotted slotted rotors are noisier than standard rotors-sort of a "crickets" sound when stopping. If you look at Mercedes factory high performance rotors, they will have only one slot for pad cleaning, along with the cast in cross hole cooling...
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
Re: Rotors and pads
Re: Rotors and pads
I have cryo treated ART (Applied Rotor Technologies) slotted rotors. They use Centric blanks. The Performance Friction Carbon Metallic Pads work very well with them. Quiet, low dust, good grip.
http://www.performancefriction.com/a...rake-pads.aspx
Re: Rotors and pads
How is the grip with those pads on the first stop when it is ice cold outside? Panic stop on the highway in winter is what I am concerned about. And did you find front and rear pads or just front? I only found fronts.
Re: Rotors and pads
Last time I purchased pads I got Centric Posi-quiet. They are good but I preferred the Performance friction. I bought rotors, callipers and pads from ART. I ordered by part number from my previous order and was surprised to get the Centric.
So to answer your question. Back in 2000 Performance had both front and rear. They required a firm application (not crazy hard) the first couple of times braking from a cold start but after that were fine. Never thought about them. The posi quiet are good but a bit dusty and some squeal. If I remember correctly the rear brakes are common with a Nissan Pathfinder. I wonder if it's just a glitch in Performance's search engine.
Re: Rotors and pads
I bought drilled/slotted/gold passivated rotors/discs from Dayle at the Motorsport Warehouse (along with SS lines) - fitted them together with EBC Red Stuff pads ...... my goodness what a difference, I have never thought the car could stop so well.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. |
Re: Rotors and pads
My dad put EBC Red stuff ceramic on his Jag XF. Instant stopping power to the point of being touchy. They grab hard on his car.
Re: Rotors and pads
I have drilled/slotted cryo rotors from Brembro that are terrific but no longer available w/this combination from Brembro. I went w/Brembro because they are not made in China and are OEM on many high performance cars. After years of use, there are no cracks in any of the holes. Although the combination is not currently available, you can purchase them cross drilled or slotted and cryo coated. Cost is still reasonable and they are a quality item. My choice for pads are the Hawk HPS; used them for years and have no complaints about cold stopping (only takes a few minutes/miles to reach temp) or dust/wear on rotors (quality rotors vs China made). My experience/two cents after over 15 years .+ of useing these products on a SVX.
Re: Rotors and pads
To update, it's the front pads which are the same as the Nissan Pathfinder.
The rear pads are FSMI No. 7351-D471 (Friction Materials Standards Institute). Seems they are only common to Legacy from 1990 - 1999 and Impreza 1993 - 1998. Performance Friction no longer makes them.
Re: Rotors and pads
Re: Rotors and pads
There is a lot of confusing information out there. For example, forums I have read had most people agreeing that the Carbon-Metallic performance pads like the Hawk HPS and the ones from Performance Friction don't stop well when cold but are pretty good when warm. However, the data shown here (http://blog.caranddriver.com/perform...c-yellowstuff/) shows the Hawk HPS as doing well on the first cold stop but fading quickly. I don't really care too much about the fading but the cold stop data conflicts with what people are reporting. Aramid based pads like the Stoptech Street Performance pads also have similar comments about their cold stopping ability not being great. My personal experience has been that ceramic pads have nice features with regards to durability, being easy on rotors and not creating dust but that they don't stop that well in general. The semi-metallic Brembo pads on my Acura stop GREAT and don't show a strong temperature dependence. That makes me lean toward semi-metallic. The problem is that there is a general belief that semi-metallics are more prone to overheating and depositing crap on the rotors which is what leads to the judder I am trying to avoid. All of this is why the EBC Ultimax pads seem to be a nice compromise. They are semi-metallic so they have the grip charateristics I am looking for but they also claim to have done something to eliminate judder.
Re: Rotors and pads
I have the Posi Quiet semi metallic. Ref: the EBC Red, I haven't noticed any difference between cold and warmed up.
