Jerky Steering.. .
My power steering was getting grabby (starting to lock-up or freeze) when I would turn (especially when cold, but even after warm) .. . especially into a parking space (low engine {PS pump} RPM). I replaced the PS pump with a reman.. . and basically now have the same symptoms.. YIKES! [The steering wheel goes from smooth to very tight (oscillates between functioning and not turning!) and creates a possible crash (esp in parking lots) scenario because of the undependable function!
Does this mean it must be the Rack & Pinion unit ($645 from SubaruParts.com).. . Or could it be something else??? Is the Rack & Pinion often rebuilt by the mechanic?.. . Should I buy an (Autozone, Pep Boys) reman unit for $300 to $390? Can I do this myself "easily"?.. . Or is this one of those high-tech items I should leave to some good ($$$) tech? Maybe this has something to do with the undiagnosed noise (previous thread) when I accelerate from a stop with the steering wheel turned (Creeking noise??). It was partly the Driveshaft hitting the sheet metal driveshaft cover (to keep exhaust heat away), but after that cover was removed (still is), it still makes a smaller creeking noise! Please give any advice ???.. . THANKS !!! I was gonna limit the advice to "cheap/easy fixes" because I'm getting tired of replacing the wrong parts.. . and especially the EXPENSIVE ONES (like the R & P).. . Ha! BUT.. I can't drive it much longer this way. It will curb my SVX. SO far, BTW, it has functioned well driving straight or mild turns. Just went on a trip (thot it was fixed!) 3 hours each way with the family (~ 300+ miles). HELP??? P.S. Why are there 2 reman R & P's at the auto stores? They say, one has a solenoid (?). My SVX is an L, so does that mean it uses NO SOLENOID? {When working under my engine a while back, I noticed an unused female electrical plug (I believe it is on the driver-side and may be where the Oxygen Sensor plugs next to it (same wire harness). Someone said that might be for the R & P "wire" ??? How do I tell if I need a solenoid version?.. . and will it work OK without? [I think I don't have a solenoid R & P now.]}
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) Valentine One Radar Detector with Remote Display - ucan'tseeme! Last edited by James Scott; 12-07-2009 at 03:02 PM. |
Re: Jerky Steering.. .
I had a very similar problem with mine last winter and there was a very cheap easy fix.
On the left side of the engine there is a steering shaft running from inside the car. On the shaft there are 2 universal joints. Spray the crap out of them with your favourite lube (WD40 etc.) This solved my issue immediately. There is also the small rubber o-ring on the bottom of the power steering pump which can wear out and let air into the system but since you replaced the pump the o-ring was probably replaced as well. |
also check your belts are tight
SVX , XV Impreza, H6 Outback |
If it is locking up as you say, I would check the universals first.
And for your question on the steering racks, yes there is a difference, the "top of the line" models (LS-L, LSi, etc) have speed sensitive steering while the lower models have "normal" power steering. Yours would be the "normal" power steering. Hope that helps |
Thanks Guys!
1) I sprayed the universal steering joints. It did seem to help, but when stopped and turning the steering wheel back and forth slowly.. It would tend to stop turning ("lock up") when going side to side (?). I will check this out further!!! If it is this.. . then I should replace those U-joints, right? They are not serviceable, are they? [Sealed Grease?] 2) The belt is tight.. . But, it does squeek just a little. [Think it's because it is not working (the power steering system).. . not cuz the belt is loose (?).] 3) Yes, that helps! The non-electric rack is cheaper! If the problem persists, I will probably install a reman rack & pinion myself (then alignment).. for about $300 here. Heh "Tom et al" .. . Let me know if you have a chinese Rack & Pinion for $100 like the axles!?.. . Ha! Thanks, Jim
There were guys on ebay who had listings for rebuilding the SVX r&p. If I remember correctly it was something like $134 plus shipping and you had to also send them your old one back. Don't know if its still on there at all.
Edit: just searched and didn't find anything. There was a used one of the type you need but they wanted $195 plus $25 shipping Last edited by 1986nate; 12-08-2009 at 02:19 PM. |
