Old 08-27-2005, 05:44 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Unhappy electrical gremlin
i was sitting at a traffic light this morning and i had my headlights on and my vent fan on med. when i suddenly heard the fan die down and when i looked up everything was real dim and the car was idling rough and my air bag light flickered on just a little bit for a second. everything was fine again when i got moving but when i got home and stopped the idle wouldn't drop below 1000 till i shut it off and restarted it and it idled at 600 like always and i couldn't get the problem to happen again no matter what i tried. something smelt hot when i popped the hood too. any help guys?
Old 08-28-2005, 06:51 AM
Budfreak's Avatar
Banned
Unhappy
well that's scary. no replies.
Old 09-01-2005, 06:55 AM
Budfreak's Avatar
Banned
Unhappy
i recently had another gremlin show itself one day. i went to start the car and when i turned the key to start, everything died for a second my clock set to 1:00 and everything popped on when i let go of the key. then it just started up and ran fine and has sincesomething elde scary was i was helping jump a friends battery this morning and when i was trying to crank on his car we heard a lod pop from my car it was loud enough to kinda stun us both and make us look over.(of course anything could stun you after 12 hours in a factory) but no problems and running fine other than need o2 sensors. when the car lost power the funny thing is the radio kept it's settings.
Old 09-05-2005, 12:00 PM
Subafreak's Avatar
Superbeast
Well I would check out the battery and charging system first. Some times with Subaru the charging lights will never come on when the car is not charging, I don't know why but it's pretty damn annoying.
Just the other day I went to go shopping in the 93 Imprezza that I've been trying to put together for the past year, I got to a stop light and turned on the turn signal and the radio shut off I then went through the light and started to get on the highway and hte car would not accelerate, noticed that the tach was not working at that point. I had to pull over to try and figure out what was happening, when I did I shut off the AC and blower fan and the radio and tach started working again So I left them off and the car would run better, enough to get me the store. When I got to the store I tried to roll the windows up and the they would barly move and the tach died again, at this point I had a pretty good idea of what was going on, and sure enough after I shut the car off it would not restart again It was not charging at all and the warning lights never came on.
So go get your system checked, I think Autozone does it for free or maybe even a local shop (I know my shop will check it out for you real quik with no charge) to see if you got a problem. You don't want to end up stuck at Stop and Shop with a dead car.
Old 09-05-2005, 12:45 PM
Budfreak's Avatar
Banned
Smile
well, the car went to absolute crap on saturday. my electrical system went completely out and i couldn't start the car. i went out after work with a brillo pad and cleaned my pos. terminal on my battery and it fixed the whole problem. didn't realize how corroded it was ever since the alt. upgrade my battery has been producing alot of corrosion on the terminal so i guess i'll just have to keep it clean. i've never seen a car act like this over a bad terminal. gotta love it!
Old 09-05-2005, 12:47 PM
Subafreak's Avatar
Superbeast
Well I hope that fixes it; that is one of the benifits of having a sealed battery mounted behind the seat......no corosion.
