Early Turn Signal Cancellation
I've noticed this since I bought my SVX.... basically, the turn signals 'cancel' to early when going around a corner. I put them on... turn my wheel, and before I 'straighten' the wheel they go off. Is there an adjustment for this? Or possibly new parts?
- Rob |
early cancelling signals
I think there was a recall for this for 92s.
Re: early cancelling signals
- Rob |
Mine does that too. Gets really annoying.
This is a recall, my SVX suffers from the same problem. I looked on alldata online and here's the information on it. I have yet to try it:
----------------------------------------------------------------------------------- NUMBER: 08-32-94 DATE: 02-14-94 APPLICABILITY 97-MY-93MY SVX SUBJECT: PREMATURE CANCELLATION OF TURN SIGNAL LEVER Affected Vehicles: All 1992 SUBARU SVX's 1993 Subaru SVX's up to P*101119 If you encounter a customer complaint of a turn signal lever that prematurely cancels before the turn is fully completed while turning right or left, it will be necessary to scrape some plastic material from the combination switch bracket stopper with a sharp scraper or a knife. Tools needed: Phillips Screwdriver Sharp Knife or Scraper Repair Procedure: 1) Verify concern. 2) Remove upper and lower column covers. 3) Locate the area to be scraped using Figure 1. The material that is to be removed is shaded light gray in the Figure. Click here for Figure 1 4) Scrape 0.1 to 0.3mm (.004 to .012 in.) thickness and 1/2 in.in length for right turn cancellation and 1 in. for left turn cancellation from the bracket stopper. See Figure 1. NOTE: If the repair is performed for a premature cancellation to the left, the wire harness will need to be temporarily removed from its holder and reinstalled after proper operation is confirmed. 4) Remove all scraped material. 5) Replenish grease as necessary. 6) Recheck turn signal for proper operation. 7) If operation is normal, reinstall upper and lower column covers.
Mike - Proud owner of a Pearl 92 SVX LS-L 5MT with 78k miles and climbing 5-Speed Status: DONE! Lambo Door Status: On hold but will be a success 04 WRX 5MT, STi Short Throw Shifter, Group N tranny mounts, AZA Z-2 18x7.5 Rims, slotted/cross drilled rotors, stainless steel lines, 35/20% window tint, ecu bead crush, power mode button; 7" In-dash touch screen LCD, mobile computer, voice recognition, alpine PXA-H701 DSP, 2 JBL amps, focal speakers all around, 5 farad cap, and fiberglassed subs in the trunk. The Mobile Computer Interface - featuring the SVX | My Locker | My Secret Stash |
I dont think it could get any more thorough than that... DAMN FINE JOB...
Chris SVX World Network Administrator -1993 Subaru SVX LS-L, Barcelona Red, #46, 160,000+ Miles (Sold to SomethingElse) -2011 Toyota Sienna SE, Black, 30,000+ Miles (Swagger Wagon ) -2002 BMW R 1150R ABS, Black, 26,000+ Miles (Daily Driver ) SVX Owner from February 1997 to March 2008 SVX Online Community Member since February 1998 SVX World Network Member since February 2002, Member #520 Life is a game. Play to win. The world belongs to those who can laugh at it. |
I just copied off the TSB from Alldata, it's exactly what the subaru dealer gets...........anyone need anything?
Thanks guys and you too Rob for bringing this up.
My SVX does the same thing but I kind of like it. I am not sure if I want to attempt this fix as the plastic could be brittle and break easy. At least the turn signal still works after 11 years.
I can run your car's VIN to see if the recall would still be considered open...if it is still open then you should be able to have it fixed.
Are you willing to run the VINs for all of us with the same problem? Thanks, Ron M.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Say folks. I wanted to resurrect this old thread , as I've noticed this same problem since before the SVX came into my posession. I did a search and it appears subarupartsgirl may have long ago departed these hallowed halls. Can anyone enlighten me as far as where this issue went from here? If I have to I'll try the outlined repair myself, but wonder if SOA took any responsibility ongoing for the problem before I start taking the column covers, harness apart. Anyone? Thanks!
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket Last edited by RojoRocket; 04-03-2004 at 02:56 PM. |
this must have been done on my 92 and had too much material scraped away. sometimes i notice i've been driving for miles with the turn signal on.
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
When I straighten out to rapidly after making a corner, my signal frequently flicks the other way. At first I thought I was just bumping it with my hand as I turned the wheel, but now I'm sure that it happens because I turn the wheel too fast. I always hold my signal on until I'm good and ready to turn it off, which I always do manually after I'm going straight. The only exception is when I'm racing around and I simply need both hands for other things.
Aside from that, mine works perfectly - in fact, better than any other car I can remember. Maybe you just can't win? |
Yo, tambein.
