Old 05-12-2001, 10:53 AM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Question What else?
Well, now that I have my tranny removed, and therefore, half the car apart, is there anything I should be replacing at this time to prevent cursing in the future?
On the list already:
Ball Joints both side, destroyed in disassembly
Exhaust gaskets and bolts
3 new exh. manifold studs where they meet the exhaust pipe (any hints on replacing?)
Oil pan gasket (leaking a little)
Tranny hose clamps, destroyed in removal
Also, how rubbery should the tranny mount be? It seems that mine is very jiggy, yet I see no cracks or other damage. Is that just the way it is?
'20 Honda Ridgeline
http://www.x35design.com
Old 05-12-2001, 07:28 PM
KEVINL
rear main engine seal
Old 05-12-2001, 08:38 PM
Stevebsy's Avatar
Administrator
Question
Is that where the oil leak is coming from? It seems to be coming from the back of the engine, I was just hoping that it was the oil pan and not the seal. So, how much work is replacing the seal?
'20 Honda Ridgeline
Old 05-12-2001, 09:33 PM
KEVINL
its not so bad you just have to to remove the flex plate remove the old seal with a small screwdriver. grease the new seal and install make sure the seal is installed in far enough or it will just leak
