My sun roof sticks when it rains. After it drys out a little it will open, but this time it didn't. It will open with a little nudge but not by itself. Would it help if I lubbed the seal arround the edge of the roof?
silver 92 SVX-"Hannah" -R.I.P. NOV. 1991-jAN. 17, 2003 red white and blue 2000 Suzuki TL1000-r-"Bethany" This grips me more than a muddy old river or reclining Buddha.(now running Metzlers! black 1987 Toyota MR2-"Helga" -Turbo conversion will now commence. 1996 Legacy Outback-"Gilda" white with brown trim |
Yes, the lube around the seal might help. This was a problem addressed by a TSB on the '92's. Mine does the same -- unless I'm up to road speed -- then, the downforce aids in opening/closing. I used a silicone gel called Sil-glide I purchased from Autozone. This is also a good product to have around for winter. If you smear a little on your door seals during winter, it keeps them from freezing. It may also help to clean your tracks for the sunroof. They can get quite "gunky."
Oh, and I almost forgot, if that doesn't work, you can try adjusting your clutch nut on the sunroof. It's under that stopper, just behind the dome light. It won't move much, so, be careful. A slight adjustment is "a lot."
Ok, I'll give it a go after I do my brakes today. Thanks
I'll have to try it tomorrow, I only got one side done today and now I have to got to work. I did learn that the parking brake is a drum brake. Now I will know to DISENGAGE the darn thing when I take the rotor off.
Yep, another one of those little "subaru engineer" surprises -- The "drum in disc" brake. It can be a rude awakening for those unfamiliar.
<< another one of those little "subaru engineer" surprises -- The "drum in disc" brake>>
Actualy, this system is widely used on cars with discs on all corners.... It makes it simpler to have the hand brake in a small drum than directly on the caliper... Remember the GL10 hand brake on the FRONT WHEELS...?! Now that was weird!!! You had to "screw" the pistons back in when replacing the pads... |
Yeah, I remember the first time I put brakes on my old wagon, we had a lever bar on a C-clamp trying to compress the piston when a neighbor says, "I think you have to turn it while pushing it in on those old subarus"
Joe 90, where did you get that little picture at?
249SVX, do you meen my "cartooned" teal SVX.... Well I created it.... I've been doing these "car-toons" since I was a kid...
Yes, that's pretty darn neat!
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-21-2006 at 10:17 AM. |
I found out the hard way just like you..
Brian |
Thread Tools | |
Display Modes | |
