Front hub bolts
Today I discovered that I am missing both front hub bolts on the front driver's side hub. The reason I was checking was that all of a sudden the steering became hard, like the power steering pump was low on fluid. I have no idea how or when the bolts could have disappeared. Can anyone tell me the size of the bolts so I can pickup replacements?
Re: Front hub bolts
The bolts that hold the wheel on? The pinch bolt that secures the ball joint? The bolts that secure the strut to the steering knuckle? I REALLY do not as yet understand what you are saying. Sorry, just trying to help. Tom
Re: Front hub bolts
I guess I'm wrong about what I referred to as "hub bolts". There are two holes in the rotor on either side of the axle nut. I thought that there should be small bolts that went into the holes but I may be wrong. I remember from my many years of DIY that some car I owned had these bolts in the rotors but it may not have been a Subaru. In the SVX parts catalog (page200/201) it shows a bolt socket, part # 90112 0077, for the rotor. The rotor is only held on by the caliper/brake pads; I can move the front of the rotor sideways so I thought that the bolt sockets were missing. I checked my my wife's 95 SVX and my daughter's 99 Forester S and both had the same empty two holes in the rotors w/o bolts. So that's why I'm thinking I made a mistake; am I right or wrong? What is the purpose of the two holes?
Re: Front hub bolts
If your rotors get stuck onto the hub, usually because they became rusty you can then install a pair of 8mm X 1.25 bolts to push the rotor away from the hub.
Re: Front hub bolts
Thanks for the info. That makes sense rather than using a larger hammer.
