Stock alarm question
I am new here but trust me you guys will see more of me. I just got a '92 SVX and i have cleaned it up (you guys should have seen how durty this car was inside) and put my subs in and today the CD reciver will be going in. My only problem that i havent worked out is the alarm. In the manual it says that you can arm the alarm by pushing the button in the car. but to this day (with the ignition on, off..) when i push the button the little light still wont blink.
My other car the one ill have to sell for bearing.... is a 87 Nissan pulsar and i installed the alarm myself so i am in confusion with this high tech 92 stuff |
the bulb could be burned out - anyone wanna give a how-to on the bulb change?
If it's the light, remove the light pod, by inserting a small flat-blade scredriver into the far end of the pod (not the single switch, but the entire row of switches), being careful not to scratch it -- and pulling with your index finger on the end of the pod nearest the steering wheel. It should pop out. Make sure you have a replacement LED (don't know the part #). If you have a replacement single LED, it's a matter of pulling the old one from the white foam rubber housing (It's obvious, from the back of the switch), remembering how to "re-string" the wires to replace it. If you order the OE part number, it well already be in the foam rubber housing and ready for an out/in replacement. Then, just snap the switch pod back into the dash. Is this what you was asking, Landshark?
Ok well i just tried to get it into programming mode still no light, horn, or other cosmic happenings. Is there a hidden alarm fuse or would the switch just need replacing?
Any ideas????
Thanx, just wondered if there might have been any common problems, but this car is one of the originals so i guess it might be fried, thanx anyway.
