Old 12-24-2002, 10:52 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
Re: Re: Re: thanx, SVX. Actually that was the
Originally posted by mohrds
Yes. I do.
Doug
Good.
Randy Johnson
Mike Davis -- at Reading VI
Aredubjay's Avatar
Yes. I do.
Doug
Doug,
Do you find it ironic that we were just talking about Kuo and his long absence, last night?
Randy Johnson
Old 12-24-2002, 10:58 AM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Re: Re: Re: Re: thanx, SVX. Actually that was the
Originally posted by Aredubjay
Doug,
Yes that is ironic. Perhaps we should talk about all the other long lost members to see if they will show up as well.
Doug
1994 LSi (4/93)
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Old 12-24-2002, 11:09 AM
mohrds's Avatar
The rear stop light sensor works by separating the stop lamps into two circuits, each with two bulbs. The two center panel lights are one circuit and the two outside lights are the other.
The two circuits each go into a sensor and each current draw is measured. If it is not in balance (ie, one circuit has two bulbs, the other only has one working) the stop lamp on the dash triggers.
The manual tells you the only "fooled" instance. If one bulb from the center panel is burned out and one bulb on an outer light is burned out, the indicator will not come on.
It has a fail-safe so if all four bulbs are burned out (zero current flow) it triggers the light.
If you put higher wattage bulbs in the center panel but regular bulbs in the outer lights, it will trigger an indicator even though all four bulbs light.
If you replace your lights with LEDs, the light will trigger because the LEDs use next t no current, so the sensor thinks all four bulbs are burned out.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 12-27-2002, 03:18 PM
cascott
Talking oils well that ends well
I finally got the "stop light" problem fixed. Apparently a bulb was flaky. The "stop light" was on when I got home on Christmas Eve. I held the brake pedal down, and got my daughter to look at the tail lights. One of the bulbs was out.
I released the brakes, and went to reverse, and braked again...no "stop lights"...brake lights working
I pulled the offending bulb and I took it inside. Looking through the glass into a light you could see a hint of discoloration on the glass. It really wasn't noticeable outside, in the dark (and it's dark here most of the day) .
The brake lights all work, and the "stop lights" is out..finally.
Now if I can just get the seat to un-recline....
thanx for all of the input.
r/-cas
Old 12-27-2002, 04:57 PM
kuoh kuoh is offline
Hmm...the one page of the manual I didn't memorize.
Whoever Subaru got their exterior bulbs from, they sure don't like to go out. I have yet to have to replace any save the headlights, and that was only because I wanted to try the coolblues. Now the dash and sunroof switch bulbs are another story.
KuoH
Brake Light Bulb Out Warning Light ------ STOP LAMP
Old 12-27-2002, 04:58 PM
I have yet to find that switch.
KuoH
BTW, does anyone know how the "stop lamp checker" works?
Old 12-27-2002, 05:01 PM
Aredub,
Stop abusing your powers of mind control over me!!
KuoH
Old 12-27-2002, 07:28 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Doug
We face that every time we use the brakes. When I open my car up this weekend, I will take that bulb out.
L
Lwin M. Maung (Member # 147)
Current SVX: NONE
