Old 10-26-2016, 09:18 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Red face Gear Firm-Up Unit Schematic
Someone was after a Gear Firm-Up Unit.
So I would like some people (more than one) to check my reverse engineered schematic of an existing unit - see posting number 8.
If there is a general requirement for PCBs then I could get some bare boards made (supply a BOM so that individually you can buy components from your local electronics shops such as Jaycar etc)
Old 10-27-2016, 03:44 PM
Re: Quick-Change schematic
Steven, I would have thought you would have had the courtesy to ask me before using my design.
I do not intend to build it any more, but I must insist that you do not use the name “Quick Change”, “QC”, or “Slick Shift” in any work that you do.
Please remove those words from the post and use a different name to disassociate it from me.
Thanks Harvey Davis.
Old 10-27-2016, 07:03 PM
SURTEESS's Avatar
Harvey,
How are you keeping these days - are you still in Australia?.
Sorry I was trying to remember who to contact in order to do this - will do it now.
Unsure how to change the heading ?? any suggestions ?
regards
Steve
Old 10-27-2016, 09:21 PM
Originally Posted by SURTEESS View Post
Harvey,
regards
Steve
Still in Australia, why would I move from Gods Paradise?
Thanks, the name change is fine, maybe a mod can change that heading for you.
Cheers Harvey.
Old 10-28-2016, 03:56 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
I can update it, what you want to say?
'20 Honda Ridgeline
http://www.x35design.com
Old 10-28-2016, 04:58 PM
SURTEESS's Avatar
Can you change the heading thread to say - Gear Firm-Up Unit
thank you
Old 10-28-2016, 06:19 PM
Re: Gear Firm-Up Unit Schematic
Thanks Steve.
Old 10-29-2016, 05:48 PM
SURTEESS's Avatar
removed as out of date
