Old 06-23-2011, 08:25 AM
svxpensive svxpensive is offline
Help please.
Hi members.
I am in quite a bind.
My 97 is parked on the street with the shifter cable broken while in park. I have to, push move the car or the city will tow it tomorrow.
I was looking for a switch that some cars have that disables the gears and puts the car in neutral.
Can anyone tell me if this can be done on the 97 svx ?
Old 06-23-2011, 09:21 AM
Re: Help please.
You would have to safely crawl underneath the car and manually put the transmission into neutral either using what's left of the cable or the switch right on the passenger side of the transmission.
Old 06-23-2011, 09:40 AM
Re: Help please.
Thanks.
As it turns out I will need a tow truck to move it because it has to move 8 blocks.
I guess it makes sense to have the tow truck first lift it and then get under it ?
The switch on the passenger side of the tranmission sounds easiest versus using whats left of the cable right ?
I would be doing it myself. Do I need any tools to use the switch ?
I want to be ready and prepared when the tow truck gets there.
Old 06-23-2011, 09:58 AM
Re: Help please.
You will be able to move the switch by hand. I don't think you need to move the switch for towing but you must not tow with the rear tires on the ground or you will damage the transmission.
Old 06-23-2011, 10:27 AM
Re: Help please.
I wanted to have it in neutral so I can manuver it into what will be a tight parking spot at the garage its going to. The flatbed tow truck will actually have a tough time getting inside the door of the garage so having it in neutral is critical.
Also, just to be clear, my shifter is sliding up and down. It is not locked into position at all.
About 2 1/2 years ago I ordered this cable myself because the shifter was locked into Park. I had a friend install it. (He moved out of town to find work and I do not have his contact info.)
After he installed the cable the shifter would always want to go into 2nd whenever I put it in Drive until one day it just started sliding.
I am thinking that its possible that the cable is not stripped or broken but simply came loose. What do you think about that theory based on the info I just gave you.
Btw, is the pasenger side switch right under the shifter or towards the front or towards the back ?
Old 06-23-2011, 10:40 AM
Re: Help please.
The shifter cable attaches to the switch on the transmission forward of the shifter, on the passenger side of the transmission.
Best bet is to get under the car and have a look.
Old 06-23-2011, 11:55 AM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
Re: Help please.
Sorry this doesnt have anything to do with your shifter cabls issue...but I just noticed youre up here by me! Nice
Jared
1992 dark teal SVX LS
Old 06-23-2011, 12:09 PM
Re: Help please.
Cool beans man.
Old 06-23-2011, 12:21 PM
Re: Help please.
No problems rolling the car around in neutral...just no towing with the back wheels on the ground.
Old 06-23-2011, 09:44 PM
Re: Help please.
I had the pin that holds the cable break apart on one of mine once. Not the safest thing, but I started it up in park, Pulled the e-brake as hard as I could, opened up the hood, and reached down to the gear selector on the passenger side of the transmission to put it into drive, while at the same time ready to pop it back in neutral in case it happened to start moving. And was able to get back in the car and drive it home where I put the cable back on with a new pin.
It can be done without crawling on the ground.
*disclaimer, I do not advise anyone to use the above method and am not responsible should injury occur to you, your car, or bystanders.
Old 06-24-2011, 09:28 AM
Re: Help please.
I got it in neutral from underneath and had it towed on a flatbed last night.
Now I am trying to find the part.
I called the dealer and he said its part# 35151PA000 for $104.
Anyone know another place to get this part from ? Most online stores dont seem to have it.
Also is this a part thats a good idea to get used ?
Old 06-24-2011, 10:08 AM
dbarnblatt's Avatar
Re: Help please.
Subaruparts.com has it for $68.73... here.
Old 06-24-2011, 12:28 PM
Re: Help please.
Thanks a million everyone. I just ordered the part.
This forum is awesome.
One more question.
How much time should it take a mechanic to remove the old cable and put this new one in ?
Old 06-24-2011, 01:50 PM
Re: Help please.
A good mechanic should be able to install the cable in an hour or less.
Old 06-24-2011, 05:02 PM
Re: Help please.
What he said^
