Old 05-25-2010, 01:30 PM
Frogman75 Frogman75 is offline
Question Engine Sometimes Cutting Out on Acceleration
My '92 is in great shape- runs smooth- but new problem....at times when accelerating for some reason the engine just dies!! Have to pull over asap and put into park and restart- Have added fuel cleaners...Any ideas??
Old 05-25-2010, 03:39 PM
Cam Cam is offline
Re: Engine Sometimes Cutting Out on Acceleration
I would start with the MAF. Easiest way to check it is to replace it with a known working one. You can also attempt to fix yours if it is repairable. There are documents in the How-To Documents.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 05-25-2010, 04:59 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Seconded, do you have a check engine light on? Even if not, id still check for memory codes, just in case something was stored.
Old 05-25-2010, 05:04 PM
Francis Francis is offline
thirded ? how u say i am third aproving ?
Claret 92 Ls-l R.I.P - 24XXXX - kms "april 2008"
rest in pieces
Ebony black 92 Ls-l Alive - 25XXXX - Quick change, Powermod , Alternator Mod , audiobahn 1300 watt ach ,exile 800 watt peak, jackhammer 12" 300 watt rms, polkaudio 6 1/2 compoment. kenwood dvd\nav . radar detector.small car lens and grill
Old 05-25-2010, 05:30 PM
macadamianut macadamianut is offline
Random or sudden stalling, it would seem is the MAF. It was in my case too.
Mac
__________________________________
1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and .....
1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs
Old 05-25-2010, 08:42 PM
I hate to sound stupid, but what is the "MAF"? I don't see it in the How To docs......Thank you all for your help on this!!
Old 05-25-2010, 08:53 PM
Wikedjuggalo's Avatar
Rebuilding
MAF = Mass Airflow Meter its attached right to the box that houses the Air Filter..
Old 05-26-2010, 05:29 AM
Again, I hate to appear idiotic, but I can't find which articles in the How-To Docs cover the MAF....Please take the trouble to continue steering me in the right direction.....MUCH APPRECIATED!!!
Old 05-26-2010, 07:38 AM
SpadedOne SpadedOne is offline
http://www.subaru-svx.net/forum/showthread.php?t=53957
1992 SVX LS-L: For sale
1995 Lexus SC400- Lexta Z
