Old 11-23-2009, 10:06 AM
The1One1AndOnly The1One1AndOnly is offline
Looking For Some Parts
Looking For Headlights, A Visor, And A Battery Bracket.
Need the engine cover bolts as well.
And if anyone has a decent T-Belt kit with a water pump that would be great, or you can guide me on wich replacements are needed most...Idlers, Tensions, W-Pump, T-Belt, Seals, Gaskets....Ill order from liberty.
Thanks Regards Max
Old 11-23-2009, 10:24 AM
Wikedjuggalo's Avatar
Rebuilding
Re: Looking For Some Parts
Ebay usually has a timing belt kit for dale that inculdes the pullies. They also offer a water pump in the kit occassionally. Start there because if I recall getting all the idle pullies and what not are expensive from subaru. I purchased a set and put it on the barcelona, ran great ( did not purchase the water pump).
Old 11-23-2009, 10:26 AM
I would look at this timing belt kit on EBay Has everything you would need. CGI is a good product.
You should be able to use the old belt tensioner
I would use a NEW Subaru water pump. The part number is 21111AA033 $114.26
Don't forget the Water Pump Gasket 21114AA051 $3.02 and the Water Pump Seal 21116AA020 $3.50
Battery bracket for the SVX available from your dealer 82182AA030 for about $14.00.
Old 11-23-2009, 10:39 AM
I would look at this timing belt kit on EBay Has everything you would need. CGI is a good product and is the one I have on my 96 Polo.
You should be able to use the old belt tensioner.
Any sealing/ gasket information can be found in the How-To documents HERE
Old 11-23-2009, 11:16 AM
Thanks A lot Guy's...... I'm looking into it now, really appreciate it.
Old 11-23-2009, 01:45 PM
jrturbosvx jrturbosvx is offline
hi check your pm.i have all the parts you need and im right in ct.thanks,Josh
