Fuse for Lighter?
Hi all ,
I have a 92 JDM and can't find the Fuses for the Cig-Lighter and heated mirrors. Do they run off the same fuse? I've checked all the fuses under the bonnet (hood) and by the drivers side foot panel. Any clues? Thanks |
Re: Fuse for Lighter?
What is the problem you are having? What is not working?
The fuse curcuit (#3) 20A, controls the cigarette lighter, the outside rearview mirrors and the heated mirror defogger. The fuse is in the interior fuse panel above the kick panel. There is a fusible link on the back of the lighter which blew. It is a short black wire. Comparing it to a new one, you can see the shriveled portion of the wire. We did a continuity test between both ends and it read open. You can replace it with a short piece of wire. .
