Old 02-14-2009, 02:14 PM
HMacmillian HMacmillian is offline
Sunroof Problems
I took my SVX to the car wash today and water started to come in through the sunroof. I checked the seal and it is coming off. I have the same problem with the passenger door. Are there quick fixes to this or do I need new seals? If so where can I get a new seal for the sunroof? I have already looked at a few places and found nothing. Any help would be appreciated.
Old 02-14-2009, 05:04 PM
Re: Sunroof Problems
I thought I would include a few more details. One, the sun roof seal if coming off on the front of the sunroof but is still attached the rest of the way around and it is not suffering from any kind of dry rot. It is not torn or damaged in any sort of way so would some sort of glue fix this?
Old 02-14-2009, 05:45 PM
They sell an actual weather stripping glue. Contact cement should work also. Something that stays pliable when dry.
Old 02-14-2009, 05:53 PM
Green1995SVX's Avatar
I think you may have more of a problem than just the seal coming off. Check for a clogged sunroof drain, too.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 02-15-2009, 09:46 PM
Hondasucks's Avatar
Subaru Technician
Sunroofs are not designed to seal, they WILL leak, and drain out the drain tubes, if one of the drains is clogged, it will leak into the car. Check your drains, you can usually blow them out with compressed air, just be careful not to blow the lines off the sunroof. There is a factory Toyota tool that's basically a pipe snake but for sunroof drains, it also works pretty well, but kinda spendy.
1986 VW Jetta
Old 02-17-2009, 10:09 PM
Thanks guys for all of the help.
Old 02-19-2009, 02:26 PM
It was warm today and I rediscovered a problem that I had forgotten. When I open the sunroof it moves very slowly and shutters at the halfway point. I looked at the tracks and they have what looks like grease residue. Should I re grease the things or is there a possibility the motor is broken? It opens and closes all the way I just want to put everything in working order on this beast.
Old 02-19-2009, 02:42 PM
Try cleaning out as much of the current grease that is in there first. Then try lubricating the track with some silicone spray.
Old 02-19-2009, 02:47 PM
Okay thanks, that is what I figured I should have done, I just didn't want to grease it then be told that such an act was a mistake. Thanks.
96 LSi with 100,000+ Miles
Owned Since Late June 2008
Things Fixed Thus Far
Airbags-Self Installed (I hope they work)
