Old 07-29-2008, 05:22 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Can you add this info to the How-To Docs
It would be very helpful for the addition of another line in the "Clearing Codes" section after problems have been resolved.
I would add in between lines 2 and 3 saying "if codes don't clear after removing pins, disconnect the negative battery cable and leave sit overnight."
Then step 4 saying connect neg. battery cable next day and check codes again. (steady blinks = everything ok).......something like that.
I was able to do this above and cleared my check engine codes.
Thank you much for those who helped.
1995 Subaru Svx L / AWD
Old 07-29-2008, 08:14 PM
kwren's Avatar
kwren kwren is offline
Re: Can you add this info to the How-To Docs
Why??
The best way is disconnect neg terminal
turn ignition key on to run... not start position.
Turn headlight switch on a couple of seconds.
Reconnect neg battery terminal and...Just go on with your life.
Keith
Information was submitted by... I will get the name BRB
ShiuludeSVX that is it! That is the guy!
Old 07-30-2008, 08:11 PM
msvx95's Avatar
It's just a phase
Because what you just said did not work. Did you read any of my posts before Keith? The only way mine cleared was to disconnect and let battery sit disconnected overnight. Some others may have experienced the same thing, but it wasn't in the original write-up.
It would be helpful to have this somewhere. I'm sure not all of us know the little tips and tricks.
I was happy to get mine working and would like to share this info.
Old 07-30-2008, 08:16 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Glad to hear it workeed out for ya
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-30-2008, 08:49 PM
kwren's Avatar
I did! sometimes they are hard to clear. That may possible be because the problem is still there. I try all the ways till I get it to clear. Sometimes we need a lot of help with these cars!
Whatever does the job for us! Get all the information we can...
Thanks,
Keith
Old 07-31-2008, 08:32 AM
msvx95's Avatar
It's just a phase
Thanks Seth....
Weren't you a tech at one time for subaru?
Old 07-31-2008, 03:57 PM
I work at a Subaru dealership where I do collision repair, but they also have a mechinics shop I poke around in here and there and ask the Subaru master mechanics just about every question I can think of.
Seth
Past subies:
Other toys:
