Old 05-07-2008, 04:31 PM
kwren's Avatar
kwren kwren is offline
I did it!
I elected to use a breaker bar and a long, heavy duty, floor jack handle slipped over the breaker bar with a great place to rest it. Worked like a champ.
Got the thing apart and timing belt covers removed, lined up the crank sprocket and the belt has slipped!
I am encouraged finding it out of time. That is great new... Not out of the woods till I change the cam shaft... and get a new timing belt installed... put back together and it works!
I Don't count my chickens till they hatch.
Thanks again for all the help everyone!
You are all priceless,
Keith
Last edited by kwren; 05-07-2008 at 04:32 PM. Reason: just did an edit to brag! no words speled rong. LOL
Old 05-08-2008, 03:08 AM
:banan a:
good for you
blk 92' LSL w/ average mods
Old 05-08-2008, 07:28 PM
lechnoid's Avatar
lechnoid lechnoid is offline
Tech & Almost Lawyer
Glad you got it loose
One trick that I've used over the years on many car is this...take an old belt (doesn't even have to fit for the car) and wrap it around the pulley once. Take a small, alligator-mouthed vise grip and clamp it so the belt is tight around the pulley. Take the slack from the belt and put it around whatever other pulley seems to be a good distance. As you start turning, the belt will grab and hold the pulley in place.
This is good for any engine, not requiring it to be able to turn over or needing rotation in a specific direction.
Old 05-08-2008, 11:06 PM
Hondasucks's Avatar
Subaru Technician
We have a tool that fits into the four holes on the crank pulley that you put a breaker bar on, and you hold the pulley with that tool, and loosen the bolt with another breaker bar and socket.
What dealership did you take it to? I know it wouldn't have taken that long at my dealership!
1986 VW Jetta
Old 05-09-2008, 01:02 AM
kwren's Avatar
p.m for you
Old 05-09-2008, 08:04 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Right
Yep, that's the tool that I just bought on Ebay.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-11-2008, 06:42 PM
dromano's Avatar
dromano dromano is offline
Re: Getting the big old bolt loose...
That tool wouldn't work for me, I have an Unorthodox Racing billet aluminum under drive pulley, I think I'll try the old belt wrapped around the pulley method.
When I last put the crank bolt in I used thread lock cause the word at the time was "you don't want that bolt to come out".
Do I have to use heat to break the thread lock? I think it takes 300 degrees.
The good news: the bolt has stayed in place for 7 years.
Anyone over come removing a bolt that has been thread locked?
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 07-12-2008, 06:29 PM
dromano's Avatar
Bump!!!!!!!!!!!
Old 07-12-2008, 09:07 PM
I use more Red Thread Locker than the Military!
And I use a breaker bar with the TQ locked with a flat pry bar.
Then again my diet is red meat
Old 07-12-2008, 09:32 PM
corncrasher corncrasher is offline
I have used the starter method on literally hundreds of crank pulleys, not near as scary as it sounds. The subaru special tool works good to.
Old 07-12-2008, 10:25 PM
kwren's Avatar
Big breaker bar with a floor jack handle slid over the breaker bar.
Hint:
Let the jack handle rest on some kind of protector and rest it on the side with the battery on it. The last part of the preceding sentence is vital!!
This really is the only way to fly and turn off the key the instant it breaks the nut loose.
Keith
Old 07-13-2008, 10:36 AM
dromano's Avatar
I'm also a big chicken. Is the thread lock strong enough to cause the crank bolt to snap in two? How much torque would you estimate it would take to make the thread lock turn in the crank?
The mention of the jack handle made me think of this: what about putting a piece of 2X4 on the floor jack, put the jack under the crank pulley, jack up till pulley is not going to move? Any chance of damage to bearings, etc,?
Old 07-13-2008, 11:08 AM
kwren's Avatar
I also was a big chicken.
The long floor jack needs to be slid down over the handle of the breaker bar and rested on the car by the battery. your thread lock is a baby and probably had no value for the 7 years. If the bolt is put on right and tightened well it will never come lose by itself. I think some dealers don't tighten it right to screw the customer... it is like money in the bank for them... when the pulley comes loose they can screw you again.
Don't think your starter will ever realize your thread lock was in the equation!
Brace up and bite the bullet! Just close your eyes and hit start!!!
Keith
Old 07-13-2008, 11:11 AM
kwren's Avatar
We will all be standing by awaiting the positive report of this endeavor!!!!!
Keith
Old 07-13-2008, 01:51 PM
The crankshaft bolt is a big bolt, 14mm X 1.5
Thats bigger than the wheel studs at 12mm X 1.25
The torque specs for the crankshaft bolt are 108-123 ft/lbs.
Most 1/2" drive torque wrenches are about 16" long from the center of the drive to where the outer end of the handle is.
If the average mechanics hand is 4" wide, you would figure the center of pull at 14"s.
To keep the math simple, lets use 15" as the pull point.
So to pull 120 ft/lb of torque you only have to pull 105#s.
Lets say the mechanic is distracted after finding out his cheating wife just spent $3000.00 on lingerie that hes never seen.
Without thinking he pulls 210#s of torque.
The crankshaft bolt is now streached and improperly torqued to double what it should be, 240ft/lbs.
The bolt does not break, but he dented the fender that he was leaning on.
OK, OK, I kid.
If he pulled more than 150 ft/lbs he SHOULD know it.
ESPECIALLY with a torque wrench!
So my best guess is that it might be torqued to 150-160 ft/lbs.
At which point red thread locker is not even an issue.
SO, if you use a torque wrench set to 150-160 ft/lb you should feel safe in removing it while holding the torque converter still with the afore mentioned pry bar.
Last edited by svxfiles; 07-13-2008 at 01:53 PM. Reason: Blew milk out my nose after reading my post, and had to clean the screen.
