Old 04-15-2008, 06:43 PM
nextse7en's Avatar
Graphic Artist
First youtube technical request.
Yea, I know I could have done it better. I thought it would be a good test of this format in the technical Q&A section... I think it holds a lot of promise.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 04-15-2008, 10:49 PM
Um, OK, so input then? carbon build up on pass side could be p.s. leaking and on drivers side could be (like you said) dipstick issue.
Did you check to see if the intake bolts are tight?
Why pull the motor for the vcg's? they are easy enough to do in the engine bay. I must have missed something.
blk 92' LSL w/ average mods
Old 04-15-2008, 11:32 PM
nextse7en's Avatar
Graphic Artist
I'm pulling to...
A. Rebuild the engine in the event that it is is burning oil.
B. Reseal the engine if the internals are fine.
C. Paint the engine bay.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 04-16-2008, 06:48 AM
RSVX RSVX is offline
Network Design Administrator
I think all replies in this thread should be in video format...
Life is a game. Play to win.
Old 04-16-2008, 10:37 AM
Manarius's Avatar
Manarius Manarius is offline
Fouling plugs or dirty injectors? Smoke might be from a bad combustion - same with the carbon. I'd go there first 'cause that's cheaper than pulling the internals.
-Jason
-Obi Wan Kenobi
Old 04-16-2008, 11:38 PM
Myetball's Avatar
Myetball Myetball is offline
Mr. Inappropriate
Dipstick popping out....bad PCV valve or bad rings=excessive crankcase pressure. Oil burning on startup is usually bad valve seals.
I'd start with the PCV valve and go from there. You'll probably find all the hoses under the intake manifold are brittle as light bulb glass and will break when you start to mess with them. A compression check would be a good idea. Not the easiest thing to do with the engine in the car.
Old 04-17-2008, 06:06 AM
AUSVX AUSVX is offline
Registered Loser
I also get the oil dipstick popping up and I always just push it back down. Why does this happen? I've been told the PCV Valve needs to be cleaned, is this true? or could there be multimple reasons?
Old 04-17-2008, 07:07 AM
Myetball's Avatar
Mr. Inappropriate
Old 04-17-2008, 05:37 PM
Registered Loser
Old 04-17-2008, 06:14 PM
Myetball's Avatar
Mr. Inappropriate
Originally Posted by Myetball View Post
Dipstick popping out....bad PCV valve or bad rings=excessive crankcase pressure..........
Old 04-18-2008, 02:58 AM
Registered Loser
no worries, was just double checking.
