Is a 08 STi exhaust a possible upgrade for the SVX?
I was wondering if anyone had a chance to see if the new STi exhaust would fit a SVX. These things should be selling for real cheap once people start upgrading their STi's.
Probably would be rather difficult to make fit.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
Long answer: you can make just about anything fit for enough money
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
it'll fit one of my legacy quite nice with minor mods
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
This is an SVX forum man, let us stick to it
Otherwise I can fit the 08's in my dad's Jeep or my sister's BMW or in my Nissan's
I will give you the best answer possible.
The STI exhaust is not tuned to work with the SVX. That is all you need to know.
Even if you were given a STi exhaust for free it would be a dumb idea to try it on an svx.... Period...
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Well I saw this thread and thought it looked very similar and might be worth checking out.
Not sure how it could be any worse for performance than the stock SVX unit considering the STi makes 75 more hp in stock form. |
Yeeeouch....
By exhaust do you mean front to back all pipes and mufflers, or just the muffler? If you look under a new Subaru, you'll see that the exhaust system is totally different from ours. The muffler might be a similar shape, but the rest is completely different.
I meant just the muffler.
it makes 75 more hp...... profound....
It is built with newer technology AND is turbocharged......
I'm sure you could make it work, if you wanted to invest the money/time. A new 08 muffler can't be cheap
Personally, I would rather find a suitable aftermarket muffler. You could probably build most of a custom system for the price of the '08 muffler, and get as good/better results. I had the idea a while ago of trying a Mazda RX-8 muffler, because it looks very much like the stock SVX one, but why? An OEM one wouldn't do me any more good than my stock part, and the aftermarket ones are $600-$1000.
This now has me wondering a bit. How does the volume of exhaust from the 2.5 at full boost (10-12psi?) compare to the volume of air exiting the 3.3? Are they similar in this fashion, cfm wise? Maybe that muffler wouldn't be a bad experiment after all.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
The muffler alone wouldn't really do much for performance. The stock pre-cat pipes off the headers are pretty tight. It would be like putting a firehose nozzle on a garden hose. Outlet size doesn't matter if there's restriction earlier in the line.
Maybe the newer technology will flow better than the one designed 13 years ago that is on my car. If it can flow enough for an STi it will flow enough for a NA SVX |
