Old 06-13-2007, 05:47 AM
SVX_MY_BABY's Avatar
Originally Posted by Earthworm
Is there a place that confirms this? I looked on Joe Spitz and they say 3.90 final drive and 3.545 reverse gear.
When I was actively pursuing this I read in the Subaru manual that the '06 has a 3.90 final drive. Can't swear by it but, pretty sure the reduction gear is 1.0:1.
This link will be helpful:
http://forums.nasioc.com/forums/show....php?t=1201152
Old 06-13-2007, 09:15 AM
XT6Wagon XT6Wagon is offline
-Stock R160 can be used without changing the gear ratio due to change in 06 that makes the ceneter diff a 1.1:1 vs the old 1.0:1
there you go, if thier info is accurate, the STi does have a 1.1:1 reduction in the transfercase.
So the final drive *is* 3.9, but they do an initial 1.1:1 reduction to lower driveshaft speeds and then a 3.545 rear diff
Old 06-13-2007, 08:59 PM
Nice...if my 5spd ever packs it in I'll be looking for a USDM 2006+ 6 spd!
Old 06-14-2007, 08:23 PM
One notes that the 2007 is different than the 2006 so, research that.... The ratios are certainly a hell of alot better
Old 06-19-2008, 09:50 PM
SubaruSVXCrazy's Avatar
SubaruSVXCrazy SubaruSVXCrazy is offline
AWD..... NOTHING COMES CLOSE
Send a message via AIM to SubaruSVXCrazy
Re: 6 mt
I need to keep this stuff in mind for later. Got to get up the money.
1992 Subaru SVX LS-L #5045 Dark Teal
1992 Subaru Loyale Wagon Gray (SOLD)
1999 Subaru Impreza 2.5RS Coupe Black Ruby (SOLD)
1969 Subaru 360 Deluxe Ivory White
2005 Subaru Impreza WRX STi World Rally Blue
1993 Subaru Legacy L Wagon Teal Metallic (SOLD)
1998 Subaru Impreza 2.5RS Coupe Rally Blue Pearl
[SIGPIC][/SIGPIC]
Old 06-27-2012, 12:47 PM
fluo fluo is offline
Re: 6 mt
Hello,
I have a question about the 6spd swap. I converted my svx from 5mt to 6mt sti. When i had the 5mt installed , it was very loud inside the car. While driving, you heard the transmission. It was like a dogbox but it ran fine.
Now, the 6spd is even louder, like a truck.
Did you cover the shifting gate with something? In this pic , there is a rubber boot installed. http://www.redlinegoods.com/images/F...install-04.JPG
Could it be the reason for this problem?
Thanks
Old 06-27-2012, 12:57 PM
Re: 6 mt
Originally Posted by fluo View Post
Hello,
Thanks
That could definitely be the problem. I have the same issue, and mine is drowned out by the exhaust at highway speeds when it's the loudest, but I am pretty sure that putting a rubber "boot" type thing like on the stock M/T cars would lessen the noise from the trans greatly. Next time mine's apart I'll probably put in something like that.
Also, at least in my case, I know that the trans has a good number of miles on it, so the bearings and stuff inside the trans are getting to be whiny just due to wear, so I think that contributes somewhat.
There is a heat shield between the trans and the shifter area that is frequently deleted in m/t swaps. That also probably contributes a little.
Old 06-27-2012, 01:08 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: 6 mt
*snip about how loud it is*
True story..yours is pretty loud.
Old 06-27-2012, 01:13 PM
dragoontwo dragoontwo is offline
Re: 6 mt
I'd like to think mine is fairly quiet. I'm currently working on a plate for the stock rubber seal on the shifter. I'll put it in my thread when I finish it.
'92 SVX LS Pearl White - 6mt
Old 06-27-2012, 02:53 PM
Re: 6 mt
I recently made one of these;
http://www.subaru-svx.net/photopost/...8&limit=recent
Now lets see if my link works for you guys.
Old 06-27-2012, 03:39 PM
Re: 6 mt
Yea it works :P.
That's a good idea actually. Bolted down, or glued/sealed? I wonder if it would work as well if I made it out of something thinner and more manageable to me. Have you experimented with any rubber boot-type things under the actual shift boot?
Old 06-27-2012, 04:03 PM
Re: 6 mt
Yes, you should have a rubber piece like this that seals the the transmission tunnel. In the STi it is held in place by rubber tabs, you'll have to invent a way to seat it on an SVX.
Old 06-27-2012, 04:08 PM
Re: 6 mt
Yea it works :P.
Bottom rubber boot.
Aluminum diamond plate, bolted in.
Upper leather boot.
Old 06-27-2012, 04:42 PM
Re: 6 mt
Mine sounds like this
http://www.google.com/url?sa=t&rct=j...UKcU3Ss_uycUcg
Old 06-27-2012, 06:05 PM
Re: 6 mt
Hi,
I used the automatic plate and modified it, it looks nearly the same. But its still very loud in the car (transmission and clutch noise).
I will try to get this original subaru rubber boot, which you can see @1:45min in this video:
