Fuel Pump
97 LSI...pretty sure the fuel pump is going. This morning it bogged down SEVERELY going up a hill, and the Check Engine light started blinking at me. Then on the way home, it stalled out going sround a corner.
Not happy. Anyway - I can pick up a used pump for $60, shipping included. Unfortunately, I suspect the pump is inside the tank. 1) am I correct in my suspicion? 2) I have neighbors who are very mechanically savvy (one of them is going to run the code for me tomorrow), have power tools and ramps, and can be assuaged with beer. Is replacing the fuel pump something we can handle, if the answer to numer 1 is yes? |
Yeah, it's inside the tank. It can be accessed through a port on top. In the center of the trunk line is a metal plate with 3(?) screws. Remove that plate and you'll see the top of the tank and all the fittings.
Remember all the safety things... - Open all windows and doors and trunk to ventilate as best as you can. - Disconnect the battery - No smoking
Wait...wait...this can be done without removing the tank? |
Yeah......
did you check the error code and it told you it is the fuel pump?
Just want to confirm the fuel pump/senders (they're all connected) CAN be removed through the port on the top under the backseat. I think there's one bolt that holds the whole assembly (2 pieces clipped together) on a hanger inside the tank. not really that difficult to remove/replace.
Please do not blow yourselves up!
Have the beer after, and THAT comes from ME!
(Why?) |
I would make sure it's the fuel pump before you go and rip your possibly good one out. Your description makes me think of a knock sensor or MAF before the fuel pump. Besides, as I recall, the suction from the pump is at the back of the tank, so going up a hill would cause the fuel to go more toward the pump, not away from it.
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount (), sporting a "new" tail light bar, silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
My $$$ on MAF...............
sounds like the MAF to me.......especially with the cel light intermitantly flashing.......Check your codes......mine went @ 240k but i had intermitant stall/loss of pwr symtems for months before it totaly gave out.....
92' Claret LSL 282,000 miles 1owner(ME) 07' Pearly WRX 40k Cobb Stage II (sold) SVX+$$$+GreaseMonkey = |
Roger that. I'll definitely check the codes first. Results in 24-48 hours.
Odds from this thread: MAF: 5-2 Fuel Pump: 4-1 Knock Sensor: 7-1 Make your bets. |
$5.00 on MAF
I'm thinking that when a fuel pump fails, it fails... and you walk. My money is on some other problem.
dcb |
