Old 05-27-2007, 08:36 AM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
A/C question
Shoul I add the oil first or the Refrigerant? Or Does it matter
Old 05-27-2007, 11:24 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
I don't know what did you mean by "oil"?
Are you talking about "stop leak" oil?
You need to give more info then people can give you better opinions.
First, based on your profile, yours SVX is 92? So do you know has it been converted to R134a freon yet? If it's not, you may need to convert it first, then you can put new freon in.
But again I think there's some freon which is compatible with both, so it's depended on what you get.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 05-28-2007, 12:03 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
oil first.
Old 05-30-2007, 03:30 PM
Thank you. yes I think it was already converted to the new refrigerant.
Old 05-30-2007, 10:27 PM
Yes, oil first and then charge it with the coolant.
Old 05-30-2007, 11:11 PM
SSSVX's Avatar
Earl, what oil does it mean by here? And, charge it with the coolant??
-SSSVX
Old 06-12-2007, 07:56 PM
R134 requires PAG oil and the R12 oil is not compatable with R134.
Old 06-12-2007, 10:39 PM
SSSVX's Avatar
If we can find some refrigerants that's compatible to mix with R12, so we probably don't have to convert to R12 anymore...right
-SSSVX
Old 06-13-2007, 08:45 PM
I've tried RedTek which is supposedly compatable with both R12 and R134 but it didn't last for long.
Old 06-14-2007, 05:48 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Other way around. The older(92-93) svx's are R-12, which technically can only be recharged by a service station, in the range of around $140-150. 134-A on the other hand, is 20$, and you can do it yourself, and it's quite easy. Putting 134-A into an R-12 system can distroy the system, so be SURE which you have. My 92 has been converted to 134-A, and the rings on my 94 are shot, so it doesn't hold the gas. Soon enough i plan to replace the rings though, so i can have 2 cars with AC.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 06-14-2007, 10:51 AM
AlcyoneDaze's Avatar
<-- custom hood ornament
thread hijack:
when i removed my intake manifold i had to disonnect those two hoses going into the AC compressor, letting all the Suva (134a) out of the fittings. All I have to do is just recharge the system with the refridgereant, correct?
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 06-14-2007, 11:28 AM
JaySVX's Avatar
Your supposed to vacuum the system first, and hten fill it with 134-A, due to the fact that the gas and atmosphere mixing forms a highly combustable gas, however my 92 retro-fitted to accept 134-A was not vacuumed before it was pumped, and it works fine. Depends on who you ask really.
