Timing Belt Change, Special Tool?
So I've heard that you can easily take off the crank pulley by carefully using a strap wrench. I'm also going to change out my water pump and the Service Manual shows a "Special Tool" to take off the cam pulley. Can I use the strap wrench again?
-Craig Lowthorp, Flagstaff AZ '92 LS-L, Black on White, 136k SOLD '92 LS-L, Black on Silver, 120k SOLD '01 Legacy Outback, White, |
I had to make a tool to hold the cam pulley in place. Some here have used a strap wrench successfully.
Crank pulley you can do the old "key the starter" method. Worked for me multiple times. I have also broke loose a crank pulley bolt with a strap wrench Main problem with using a strap wrench on the crank pulley is you put so much force on the rubber dampener you can weaken it or even break it loose.
Looks like it's time to get out my breaker bar...
Thread Tools | |
Display Modes | |
