Old 12-10-2004, 01:09 PM
So Greg, what's a better solution to run that much power and prolong the life of the alternator?
Old 12-10-2004, 02:12 PM
drivemusicnow's Avatar
Poor College Racer
The best option i see would be to get a second battery, in the trunk. With a battery isolator/regulator, you could run the main battery up front to run all the accesories and such, have it wired with another battery, and have the alternator charge both. If you set it up correctly, if you were WAY over drawing due to the audio equipment, the rear battery would drain fully, but you would not be "pulling" current from the alt, which is the biggest culprit to killing them. Obviously you'd want a deep-cycle battery.
Basically it would let your audio battery "feed" your main battery, but your main batter can't "feed" your audio battery. without damaging your alt.
Greg
97 Red SVX LSi clean
96 Black SVX LSi beater
90 Red Eclipse GSX track ho
99 Ford F250 work horse
Old 12-11-2004, 10:50 AM
The part I don't understand is if the alternator is charging both batteries and the stereo is draining only one of the batteries how is that easier on the alternator?
