Old 10-29-2004, 07:34 AM
A Fake Vision
Question Tranny flushing...
my wonderful friends at subaru (note sarcasm)want to flush my tranny, i heard this is bad news.. i hear that most svx trans fail after getting flushed.. i was just hoping to get some information.. thanks
dave
Old 10-29-2004, 07:57 AM
don't flush, just dismantle, clean it up, and put it back. flushing can move dirt from one place to another.... or it can harm some materials inside the tranny.
Old 10-29-2004, 08:16 AM
n00b on demand's Avatar
Ive gotten my tranny flushed twice in 6 months...( before the cooler)....no ill effects here.
Old 10-29-2004, 08:57 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
I must agree. Don't get the trans flushed.
On a low mileage SVX or one that's had its ATF changed regularly since new, you might get away with it. However, it's better to be safe than sorry!
-Chike
2006 Steel Gray WRX TR (sold)
Old 10-29-2004, 09:04 AM
A Fake Vision
what do you mean by dismantle? im confused.. and my milage is 97,500 miles.
Old 10-29-2004, 09:09 AM
Chiketkd's Avatar
What I interpret it to mean is remove the trans pan, wipe it down completely and replace.
-Chike
Old 10-29-2004, 10:19 AM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
The problem that occurs with flushing A/Ts with questionable service histories is that the soft parts (seals, o-rings, etc.) have hardened, the surfaces they ride against have accumulated a varnish that helps them seal and any disruption of these surfaces can lead to pressure leaks due to rinsing away their fragile relationships.
Most shops that provide these services know this and either refuse the job if it is questionable (and possibly a liability) or have the customer sign a waiver beforehand, stating that whatever happens will be your problem and your problem alone. Those shops that do neither usually just purchased their equipment and haven't been burned yet.
My choice if it were mine? A '92 or '93 approaching 100,000 miles is in 'start saving your money now' territory. Drain and fill the trans and replace the external campaign filter if installed.
Old 10-29-2004, 10:20 AM
A Fake Vision
okie dokie.. i can do that myself sounds like a plan.. thanks guys..
dave
Old 10-29-2004, 10:36 AM
Chiketkd's Avatar
Agreed.
When you drain the trans you may only get 4-6 quarts of ATF (even though the trans holds 10). But draining it a couple of times will keep purifying the ATF in the trans. By the 3rd or 4th drain, your trans will have over 90%+ new ATF in it.
-Chike
Old 10-29-2004, 11:33 AM
Royal Tiger's Avatar
Certified Porschephile
Also look up the other thread where we discussed this. I had mine flushed with horrible results.
Old 10-29-2004, 11:44 AM
A Fake Vision
good thing that im saving for the 5 speed...
Old 10-29-2004, 12:50 PM
i dunno i had mine flushed twice with no ill effects.
Old 10-29-2004, 09:18 PM
THAWA
As others have touched on, the problem with flushing goes back to the history of the tranny, if it's working on very old fluid, or old burnt fluid, flushing might not be that great of an idea, even a drain and fill might not be that great of an idea. If your trans has always been taken care of and always serviced at the right intervals you should be fine with this flush.
Old 10-29-2004, 09:32 PM
TorG0d
On a similar note, I had my tranny replaced about 9 months and 20000 miles ago and was planning to drain/refill it pretty soon. Any suggestions on fluid? Or will any DexronII/Mercon fluid work fine?
Old 10-30-2004, 11:40 AM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Any Dexron III would work fine, but "in my opinion" if you want to get the best possible fluid go with the Red Line High-Temp synthetic fluid. Expensive, yes....but so is the tranny...
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
