hose nipple?
If you look at the engine bay from the passenger side, between the trans and differential, right below the fire wall, I can see a hose nipple on top of the transmission. should something be connected to it? I'll try to post a photo.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
Re: hose nipple?
If I am thinking of the same spot it is just a plastic sleeve covering a long screw I believe
#1 1994 Ls ebony parts car-rip #2 1994 L laguna blue - sold #3 1992 Lsi pearl white - sold #4 1992 Lsi pearl white -Ate two engines - Rip #5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree #6 1992 Lsi custom orange parts car #7 1992 Lsi green 4.44 swap. Currently for sale #8 1992 Lsi custom pearl white. Project car... sold #9 1992 Teal 4.44 swapped... sold #10 1995 Laguna Blue. Sti 19 wheels, #11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂 |
Re: hose nipple?
There are supposed to be two breather lines on the top of the transmission that are supposed to be open to air, but pointing down (or down-ish) at the open end so as not to suck in any dust. It sounds to me like your hose broke off. Post a pic to be sure though.
Re: hose nipple?
Tee Hee! He said nipple.
Re: hose nipple?
That's what I was going to say!
Re: hose nipple?
Here is the photo of the nipp.., I mean hose fitting
Re: hose nipple?
http://www.wuala.com/dbarnblatt/Phot...812,1576615,15
Open "svx92-94_parts_5trans.pdf", then go to page 126. You're missing part # 18. There are supposed to be two breather hoses, the other one is on page 146. Double check that you have that one too. It's probably more visible from the driver's side. You don't necessarily need to have those exact lines, shaped exactly that way, but you do need a line attached to each fitting, with the other end pointing downward. The purpose of the breathers is to allow the trans to release pressure, but not allow dirt, water, and other crap into the trans. So it's not a super urgent thing to fix, but definitely worth fixing.
Thread Tools | |
Display Modes | |
